throttle body gasket template - JeepForum.com
post #1 of 3 Old 03-23-2006, 11:43 PM Thread Starter
mud-dog27
hey i was wondering if anyone has a template for the pre-HO 4.0l throttle bodies (3 bolt) reason i ask is cause i was lookin for a spacer but as most probly know no one makes them so i was going to do as other and takle a gasket to a metal shop and have one made up......problem is went to the local chrysler dealership and either the guiy was bein a dick or tellin the truth he told me that they were discontinued and no longer available...now i find this hard to belive but if anyone has a template of sort it would be much appreciated
89 wagoneer LTD. , 32x11.5R15 wild country RVT, 15x8 AR baja rims , surco safari roofrack w/spare tire kit , cobra 19 DXIII w/ high gear mic. 4' whip on a 3" heavy-duty spring , 4.5" rough country full leaf pack lift kit
mud-dog27 is offline
post #2 of 3 Old 03-24-2006, 04:44 PM Thread Starter
mud-dog27
anyone..........any one know of anyone who makes them or atleast a rough drawing.....
post #3 of 3 Old 03-24-2006, 05:09 PM
Traveller
The easiest way to do it would be to remove your throttle body and use the gasket as a template. Even if you damage the gasket removing it, you can get the appropriate gasket material from Pep Boys or wherever, and use your old gasket as a template to cut out a new one.
Traveller is offline
Stock throttle body vs 63mm throttle body? JESSETHELJ Engines & Drivetrain 40 07-14-2014 12:59 PM
4.0 throttle is sticky...i cleaned the throttle body 88peej Engines & Drivetrain 4 01-26-2010 11:59 PM
throttle body 99wrangler4x4 Engines & Drivetrain 3 09-05-2007 09:25 AM
4.0 throttle body BigD1634 Engines & Drivetrain 1 04-24-2003 05:23 AM
throttle body 2.5 vs 4.0 off-road arkie Engines & Drivetrain 0 03-24-2002 09:06 PM
