TH400 and a Dana 20 - JeepForum.com
post #1 of 4 Old 07-16-2007, 11:37 PM Thread Starter
HazMat870
TH400 and a Dana 20
I have a 77 CJ 7 with the turbo 400 trans and the quadra track transfer case but I want to put in a Dana 20 transfer case. What do I need to do other than the adapter plate?
HazMat870 is offline
post #2 of 4 Old 07-17-2007, 11:51 AM
KrazyGimp
1982 CJ5
Right off the top of me head I can think of the rear axle. The quara-track case has an offset rear output while the Dana 18,20 and 300 all have centered outputs. I have seen one person run the centered t-case with an offset axle, but there was no lift and they spent some serious money on a good shaft. Still I see problems down the road if you actually plan on wheeling it.
Check this site for info on the differences between the cases, from there you should be able to get an idea of what you need.
http://novak-adapt.com/knowledge/tra...se_gateway.htm
Here is about everything you need to actually mate the tranny to the t-case.
http://novak-adapt.com/catalog/kit_124.htm
What part of Washington are you in by the way?
1982 CJ-5 Laredo 258, T-176, D-300
1972 240z in pieces...
Originally Posted by BESRK
...that's why you push in that little nipple (hehe.. I said nipple on the internet :D )
KrazyGimp is offline
post #3 of 4 Old 07-17-2007, 03:29 PM Thread Starter
HazMat870
Hey Krazy I have a Dana 44 front and a 44 rear that I'm going to put in when I do the swap. My main worry is do I need to put a new tail shaft on my trany? I'm in Spokane. I spent last week at the pnw4wda trail ride.
post #4 of 4 Old 07-17-2007, 05:05 PM
scrounger
You will have to change the output shaft to a 32 spline unit that was in front of a Dana 20.There is also a bullgear that is needed that I didnt see in the novak link.
scrounger is offline
TH400? Connections? Rebuild? Paperboy326 Engines & Drivetrain 0 01-10-2010 07:01 AM
Rebuilding TH400 LJameson Engines & Drivetrain 1 10-24-2009 10:49 AM
TH400?'s h2oman Engines & Drivetrain 0 04-22-2007 05:44 PM
TH400 T-case XJeepness General Jeep & Off-Road Equipment 4 03-29-2005 06:29 PM
350 & TH400? hufty Engines & Drivetrain 1 02-19-2004 05:13 AM
