tf999 won't shift right - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > tf999 won't shift right
FS: Wranger BRIGHT License Plate LED! Just $3! Great valueIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 06-25-2013, 05:50 PM   #1
1993yjr
Hello, I'm new here. My transmission shifts from 1st to 2nd like butter. But, from 2nd it shifts immediately to 3rd, climbing 100 to 200 rpms before shifting. I checked to fluid and its full and in good condition as is tv cable. There's a small leak coming from the bottom of the bell housing, although I don't think that's what's causing the problem. Any help would be appreciated.
1993yjr is offline   Reply With Quote Quick reply to this message
Unread 06-25-2013, 07:24 PM   #2
1993yjr
Bump
Unread 06-26-2013, 09:29 PM   #3
baldfatdad
Get a Chilton manual and it will tell you how to adjust the band and set the down shift rod. Did you check the fluid with it in nuetral. Chryslers are off thatway.
baldfatdad is offline   Reply With Quote Quick reply to this message
