Teralow or other ID - JeepForum.com
post #1 of 3 Old 05-25-2012, 10:20 PM Thread Starter
balzer
Teralow or other ID
I picked up a 231 that is said to have a lower low range gear set in it and it also has a SYE. It did come out of a 1999 5 speed TJ but I doubt that matters much.
So how would I know if the gear set is really a lower than stock set? Was there other companies that did them other than tera? Would it be 4:1 or was another set available like a 3:1 or???
If it helps the SYE has a flat flange type yoke on the rear rather than the more common U-joint style.
Heres the back story. A friend of mine bought this 99 TJ, it now has a monsterbox? transfercase. This transfercase I have was from the jeep several years ago, but the previous owner wanted 3 stick ability and a stronger unit as well as a bit shorter. Thats basically the story I got.
I do know the previous owner by name only as he is a known name in the oilfield and has a business.
I would like to know if I could use the parts from this x-case in my jeep described below.
Thanks in advance.
2001 TJ SE
1971 J4800 gladiator
balzer is offline
post #2 of 3 Old 05-26-2012, 02:45 PM
scubamc
Was the tcase with the teralow from a 4 or 6 cyl TJ? The 4 banger tcase is a 21 spline input and the 6 is a 23 spline.
Horsepower is like a hot girl with STDs. You know you want to hit it but you're afraid of the consequences.
scubamc is offline
post #3 of 3 Old 05-26-2012, 07:54 PM Thread Starter
balzer
It was from a 6 cyl and mine is a 4...
2001 TJ SE
balzer is offline
Lomax vs Teralow vs Klune vs Stak vs Atlas JeepnBlake Engines & Drivetrain 5 10-27-2009 06:47 AM
Anyone with a teralow 4:1 paulhead Engines & Drivetrain 1 10-05-2009 03:18 PM
My 231 TeraLow kit broke JeeperDon Engines & Drivetrain 14 07-23-2006 07:01 PM
teralow or regear axels YJinSD Engines & Drivetrain 6 04-11-2006 11:40 PM
