tera low 4:1 with dana 30 front problems?? - JeepForum.com
post #1 of 20 Old 03-12-2007, 08:13 PM Thread Starter
sa_9933
2004 KJ Liberty
i am really interested in getting the tera low 4:1 but am worried about the weak front axle i have. just wondering if anyone has this set up and if they ran into problems. I'm looking to install a danna 44 in the front, but i don't have the money to do them both right now. thanks.
sa_9933 is offline
post #2 of 20 Old 03-13-2007, 06:33 AM
JSBlu974X4
the D30 will be fine. what size tires are you running, thats your issue, locked?
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline
post #3 of 20 Old 03-13-2007, 09:45 AM
Dcomf
There will be no problems with the setup you describe, the D30 will do just fine. I installed the Tera 4:1 and an Aussie up front and run 32's as well with nary a problem. Consider getting the Tera 2lo kit and installing that when you do the 4:1. As a side note, call sams4x4 for their price on the 4:1. Last I saw it was $729 delivered.
Dcomf is offline
post #4 of 20 Old 03-13-2007, 10:06 AM
frankiefire702
You'll be fine. I've ran a dana 30 with detroit ez locker and 35's for a couple years no problems.
06 tj locked on 36's.
frankiefire702 is offline
post #5 of 20 Old 03-17-2007, 10:49 AM
xyz123
Super Senior Member
I've got the terra low 4:1 mod planned for May; I've not really though about the 2-lo..but it sounds like a good idea..I'll need to research it a little, but I'll probably go with it also..
xyz123 is offline
post #6 of 20 Old 03-19-2007, 05:39 PM
miguelitojeep97
does "sams4x4" have a web site? the one i went to is just landrover stuff. 729 shipped is an awesome price! I found it on the pirate pages for 760.
I have the darn 2lo kit but not the 4:1 kit, lol but i love 2lo
1997 TJ 4.0 5 spd. rock track 4:1, 3.5 inch Rock Krawler 5 inch stretch long arm, 35 inch MTRs, Warn 9k, D44/30 locked with 4:88s, Vanco BIG BRAKES!!and more...
miguelitojeep97 is offline
post #7 of 20 Old 03-19-2007, 07:57 PM
xyz123
Super Senior Member
I've heard good things about Sam's; I know they've been around a long time..they're located in Tulsa, OK.
I'll probably give them a try sometime; I just got a price from DC4WD; he's a vendor on this site; his price was the same as above; he's been great to deal with so far..
xyz123 is offline
post #8 of 20 Old 03-19-2007, 08:31 PM Thread Starter
sa_9933
2004 KJ Liberty
i will be running 33 x 12.50 mickey thompson baja claws, with a RE 3.5" SF lift, i talked to dc at DC4wd.com and he was saying that once i lift my jeep, i'll notice a reduction in power, when i go wheeling, i'll really notice it since i have the stock transfer case with the sye and cv driveshaft...also...how hard is the install for the tera 4:1 low...does anyone know of any threads, write ups, or "how to" videos.
sa_9933 is offline
post #9 of 20 Old 03-19-2007, 09:10 PM
miguelitojeep97
http://www.stu-offroad.com/round2/Round2-3.htm
keep this in your favorites. If you ever think about doing something sweet to your jeep, im sure Stu has a write up! Ill be following his write up along with another to do it this summer
post #10 of 20 Old 03-21-2007, 02:01 PM
kercher
kercher's Avatar
i think it is sams4x4store.com
kercher is offline
post #11 of 20 Old 03-21-2007, 02:44 PM
miguelitojeep97
what about a Rubi 241 t-case? does anyone know what changes would need to be made for this install? shaft length, SYE? if this bolts right up, wouldnt it make sense to try and fin one of these? oh but it doesnt have 2lo...just looking for cheaper alternatives
oops i think i just found my answer
ghahahaha http://www.tellico4x4.com/product_in...ducts_id/15033
post #12 of 20 Old 03-22-2007, 10:02 PM
xyz123
Super Senior Member
I'm not sure how many 241's you'll find in the junkyards..If you're really serious about transfer cases..hold out of the Atlas..
for me, I'm just going to go with the 4:1 and 2-lo kit in my 231; for my application, I think I'll be satisfied.
xyz123 is offline
post #13 of 20 Old 03-23-2007, 04:47 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
Instructions come with the kit, might also be on Tera's site to download. The toughest part of the job is getting the t-case out and in, and thats just bolts. Doing the 4:1 on a bench is cake.
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #14 of 20 Old 03-23-2007, 09:16 AM
Dcomf
That's it. But there website, last I checked, routes you off to something other than the 4:1 kit when you click on it. They were going to check with their webguy to get that fixed. I called and verified the price, it is $729 shipped for them blem and $829 shipped for the regular. About the cheapest around. I got the blem about a year ago and can't tell what was blemished on it. Like JeeperDon said the hardest part was removing and installing the case from the Jeep. Just place it on your chest and raise it back up in, align, and start your bolts. Not difficult, just, well you'll find out.
Dcomf is offline
post #15 of 20 Old 03-23-2007, 09:38 AM
Slapahoe
Registered Jerk
Slapahoe's Avatar
I runt he 4:1 with a D30 up front and 35" tires. Have been doing so for quite some time. I do have 4.88's and a detroit as well as a terflex high steer knuckle.
I have had no problems with the axle associated with the 4:1. I am sure you will probably run into vacum problems assuming you do not have a posi lock unit.
93 YJ 4.0HO
'03 KJ Renegade
Slapahoe is offline
DANA 30 outers on DANA 44 front axle-- with a twist IN8LYJP Engines & Drivetrain 1 07-08-2009 04:40 AM
Tera Dana 44 Axle JSBlu974X4 Engines & Drivetrain 0 01-24-2008 09:47 AM
Tera low dana 20 algmmech Engines & Drivetrain 1 02-17-2007 07:15 PM
dana 30 problems speedracer2536 Engines & Drivetrain 0 11-26-2006 10:41 AM
Tera low dana 300 ?s mlove6 General Jeep & Off-Road Equipment 5 04-27-2005 10:19 PM
