Tcase swap - JeepForum.com
post #1 of 7 Old 07-09-2013, 09:28 PM Thread Starter
craiglawsonc
Tcase swap
Can I make a 98 231 tcase work in my 93 zj
craiglawsonc is offline
post #2 of 7 Old 07-09-2013, 09:29 PM
DaemonForce
I don't see why not. What transfer case are you using now?
DaemonForce is offline
post #3 of 7 Old 07-09-2013, 09:41 PM Thread Starter
craiglawsonc
Originally Posted by daemonforce
i don't see why not. What transfer case are you using now?
a 249
post #4 of 7 Old 07-09-2013, 09:49 PM
DaemonForce
One New Process transfer case being swapped for another. Same bolt pattern to the transmission, same clocking position, same electronic speedometer interface plug, the shifting linkage looks like it works the same way, the front driveshaft should bolt up just fine...The rear driveshaft might have to be changed. That's the one issue I see with this thing.
post #5 of 7 Old 07-09-2013, 11:28 PM
GilaMtnJeep
GilaMtnJeep's Avatar
Make sure the imput shaft matches, too. Some of them are different length and have different spline counts.
Silence is Golden, Duct tape comes in Many Colors.
Journeyman Meterman IBEW Local 611
Work with enthusiasm as though you were working for the Lord rather than for man.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
GilaMtnJeep is offline
post #6 of 7 Old 07-10-2013, 02:19 AM
DaemonForce
This is something I would normally think about but don't all the ZJs have 23 spline input shafts? This guy is using a NP249 so what does the NP231 come from?
post #7 of 7 Old 07-11-2013, 07:00 AM
GilaMtnJeep
Not schooled on ZJ's but the NP231 is in TJ's and YJ's I believe, and maybe others, too. In those models I think there is a difference with the input shaft if you are auto or manual trans.
Member 25
/l ,[____],
l---L -0lllllll0-
()_) ()_)-O-)_)
