Tcase removale, need some help?!??!? - JeepForum.com
post #1 of 2 Old 12-03-2012, 01:34 PM Thread Starter
joekachman
I took the cross member off, is there anything that I can remove to get this tcase to drop down a few more inches???? I can't get a wrench in the places needed to remove the six nuts to disconnect from the tranny.
joekachman is offline
post #2 of 2 Old 12-03-2012, 01:56 PM
Jeepin72
I assume the rear drive shaft is off? Without the crossmember and no shafts, specifically the rear, the entire drivetrain should only be held up with the motor mounts (at least on a TJ). Raise or lower the floor jack to allow the drivetrain to do the same.
Jeepin72 is offline
