Tansmission issues - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Tansmission issues
All Bilstein shocks & struts - Lowest Prices Ever and Iron Rock Offroad products - get them from Kolak!Baseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft Ki
Unread 04-29-2015, 11:39 PM   #1
big95rob
Tansmission issues
So I lent my buddy my jeep for a month as I was gone, and he calls me about two weeks after I left and tells me that 2nd 4th and reverse won't engage. I get home today and there is nothing there, no grinding, nothing that feels like a gear is even there, but 1st 3rd and 5th work just fine. Please if anyone knows what could be the issue, I would really appreciate the help
big95rob is offline   Reply With Quote Quick reply to this message
Unread 04-30-2015, 05:56 PM   #2
jeepn4life92
What kind of jeep do you have? Sounds to me like you aren't able to hit any gears that you shift towards the rear of the jeep for. If you have a tj, the hole in the jeep's floor to shift thru isn't very forgiving, a lot of guys have an issue with this when the do a tcase drop or body lift or some combo of the two, you seem to have the same problem. Take the console off (it's like 3 or 4 bolts) and watch the shifter when you shift, see if it hits the floor.
jeepn4life92 is offline   Reply With Quote Quick reply to this message
Unread 04-30-2015, 07:29 PM   #3
big95rob
I have a tj with the ax5 3 inch body lift, my buddies seem to think its the linkage, there's no grinding or anything when I try to shift, it's just like nothing's there
Unread 05-01-2015, 06:57 AM   #4
StanF
The AX5 isn't known as a robust transmission...
There is no external shift linkage on the AX5 to get out of adjustment.
You can pull the shifter boot and pull the shifter tower off and inspect it. It wouldn't take long to rule out anything shifter related.
I'm pretty certain that your problem is internal to the transmission, but you won't know for sure until you start digging.
If you have to replace or rebuild your AX5, you might consider doing an AX15 swap instead. It's a much stronger transmission. To mate it to the 2.5L, you can get adapters from Advanced Adapters or some people use an AX15 bell housing out of a 2.5L Dodge Dakota. I ran an AX15 with my 2.5L engine using the Advanced Adapters Kit, and it worked great. There are several threads on this swap - search around if you are interested. It's also a great first step to a 4.0L engine swap
Also, most of us here wouldn't recommend anything over a 1" body lift. The 3" body lift can also mess with the shifter throw, so if your body shifted for some reason, it could be the cause of your transmission problem (unlikely, but possible). Again, pulling the shifter boot would be a good first step.
My Ammo Can Console: http://www.jeepforum.com/forum/f12/yet-another-ammo-can-project-finished-1498520/
My 8.8 Swap: http://www.jeepforum.com/forum/f12/yet-another-ford-8-8-swap-extras-1565339/
StanF is offline   Reply With Quote Quick reply to this message
Unread 05-21-2015, 11:16 PM   #5
lovejeepincj5
I had put my jeep into four wheel drive high when i heard a noise now my clutch will not engage. ANY ANSWERS PLEASE
lovejeepincj5 is offline   Reply With Quote Quick reply to this message
