Taking the T-case kit out - JeepForum.com
post #1 of 10 Old 05-19-2013, 05:30 PM Thread Starter
rpapp1
I just recently switched to all adjustable arms on my Rubicon. I have 5.5 coils under it with a transfer case drop. I took the kit out and adjusted the pinion accordingly. The kit had the spacer between the skid plate and frame as well as a lowering bracket for the 4wd lever. I took both of these out. Is there anything else I should be aware of when doing this? On a separate note, what size are the OEM bolts that attach the skid plate to the frame? Thanks
rubicon27
rpapp1 is offline
post #2 of 10 Old 05-19-2013, 06:25 PM
biffgnar
biffgnar's Avatar
Did you also get a double cardan driveshaft? With that much lift stock rear driveshaft not going to work without TC drop even with adjustable arms.
Romney in 2020!
biffgnar is offline
post #3 of 10 Old 05-19-2013, 07:16 PM Thread Starter
rpapp1
No, I still have the stock drive shaft. What will happen if I just baby it for a while? Also how much would a double cardan driveshaft cost?
rubicon27
rpapp1 is offline
post #4 of 10 Old 05-19-2013, 08:31 PM
biffgnar
biffgnar's Avatar
With that much lift and no double cardan driveshaft you will almost certainly have driveline vibes and risk all the damage that can cause. Additionally, I'm surprised your driveshaft is not too short with that much lift and stock shaft. Seems like you could easily have driveshaft separate if you off road much. Double cardan driveshaft of correct length is probably $200-300 depending on where you get it. Not worth it to try to run without. Wait to remove the TC drop till you can do it right.
Romney in 2020!
biffgnar is offline
post #5 of 10 Old 05-20-2013, 09:46 AM Thread Starter
rpapp1
Will the current drive shaft be okay for going up the street? I'm ordering my CV drive shaft as we speak but I just want to make sure I'm not going to blow my TC or pinion doing so.
rubicon27
rpapp1 is offline
post #6 of 10 Old 05-20-2013, 09:50 AM
Stud_man50
Really you just have to drive and see how much vibes, any vibes are bad because it will cause seals and other things to fail on the T-case and rear axle. My buddy tried to drive after the same lift and it wouldn't make it out of the driveway. I would wait for the driveshaft to come in.
Stud_man50 is offline
post #7 of 10 Old 05-20-2013, 10:12 AM Thread Starter
rpapp1
No, I drove it up the street and pushed it to about 60mph and there were little vibrations. I guess I adjusted that pinion perfectly. I just ordered the TW CV drive shaft so ill have that on there probably within the month. I just wanted to make sure it was even safe to drive. lol
rubicon27
rpapp1 is offline
post #8 of 10 Old 05-23-2013, 08:55 PM Thread Starter
rpapp1
Does anyone know what size the OEM skid plate bolts are? I'm playin hell tryin to find em without going to the dealer!!
rubicon27
rpapp1 is offline
post #9 of 10 Old 05-23-2013, 10:25 PM
222Doc
222Doc's Avatar
Tw. Tom woods? wont take a month at least I have got them in like 2-3 days. but it is a holiday. bet you get it next week. if it vibes a little i would drive it little. a little becomes a lot'el.
222Doc is online now
post #10 of 10 Old 05-24-2013, 07:35 AM Thread Starter
rpapp1
Thanks for the heads up. Yea I sent my measurements to them yesterday but I will be out of town so it won't be driven.
rubicon27
rpapp1 is offline
