t case problem - JeepForum.com
post #1 of 3 Old 05-03-2012, 07:49 PM Thread Starter
jeeper413
t case problem
My jeep wrangler makes a grind noise When in 2 wheel only in reverse. Its all fine in 4 wheel hi/low. The t case is a 231j and it has a standerd trans.
jeeper413 is offline
post #2 of 3 Old 05-04-2012, 08:25 AM
MoparXJ
1993 XJ Cherokee
Check the vacuum lines, the gears might not fully retract and rub in 2 but are engaged when in 4.
MoparXJ is offline
post #3 of 3 Old 05-06-2012, 08:14 PM Thread Starter
jeeper413
I rebuilt the t case with one i found with a broken chain! The 2wheel gears were All in t case What a mess. Used gears and fork from a newer 231j and It got the trails last nite..
Transfer Case Problem? vanhorn1290 Engines & Drivetrain 8 03-05-2012 03:24 PM
88 yj transfer case problem? brianOU Engines & Drivetrain 5 09-08-2011 11:07 PM
t case problem only in 4 lo 98jeepzj Engines & Drivetrain 10 05-31-2011 06:01 AM
transfer case problem reomack Engines & Drivetrain 0 03-07-2010 06:05 AM
t-case problem young yeller Engines & Drivetrain 3 06-23-2007 08:36 PM
