T-Case identification? - JeepForum.com
post #1 of 2 Old 10-28-2012, 07:27 PM Thread Starter
jeromeo8503
1979 CJ7
Quadratrac shift linkage?
Can anyone tell me where I can get the shift linkage for the quadratrac transfer case? This has been asked a couple times, but the only response was from someone who "has this in the garage". Also, if the lever on the case is all the way to the back, is that in High? I know mid is neutral, but I am not sure about Low/High. Thanks.
Last edited by jeromeo8503; 10-28-2012 at 10:51 PM. Reason: Realized my mistake...
jeromeo8503 is offline
post #2 of 2 Old 10-29-2012, 06:53 PM
90DesertTanYJ
If your in low range it will be pretty obvious as you will be screaming in 1st and usually accompanied by a hard shift. Did you post up in the CJ Tech? Might get a better response there.
90DesertTanYJ is offline
