T-case check bolt frozen - JeepForum.com
post #1 of 7 Old 10-17-2013, 03:09 PM Thread Starter
longislandxj
1994 XJ Cherokee
Does anyone have any suggestions to what i should do to remove to check bolt
Thanks
longislandxj is offline
post #2 of 7 Old 10-17-2013, 03:55 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Filler plug?
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is online now
post #3 of 7 Old 10-17-2013, 06:16 PM Thread Starter
longislandxj
1994 XJ Cherokee
Ya thats what i meant the filler plug
post #4 of 7 Old 10-18-2013, 07:13 AM
0125JeepGuy
Originally Posted by longislandxj
Does anyone have any suggestions to what i should do to remove to check bolt Thanks
try soaking it in some lubricant like WD-40 or whatever u use then put a pipe over the wrench for extra leverage. thats about all you can do. i would not recommend using heat
0125JeepGuy is offline
post #5 of 7 Old 10-18-2013, 07:15 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I would heat the plug up with a propane torch and then let it cool for 10 minutes. Do it a couple more times. Then loosen it.
post #6 of 7 Old 10-18-2013, 08:31 AM Thread Starter
longislandxj
1994 XJ Cherokee
Ok thanks just hope i dont crack the casting with too much heat wish me luck
post #7 of 7 Old 10-18-2013, 04:24 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
You won't.
