T-176 shifting issues... 4th too "loose," reverse resistant - JeepForum.com
post #1 of 2 Old 05-20-2013, 12:56 AM Thread Starter
mojo_matic
1980 CJ5
O.K... picked up a solid '80 CJ. T-176 transmission.
4th gear: I can shift "too far." I can vaguely feel where the 4th gear "stop" should be, if I pass this point, shifter becomes loose in one direction. I have no problem shifting back into third..... but I can feel this is not right.
Reverse: Transmission drops into reverse fine, but needs a little finesse to shift out. If I shift straight out of reverse as I "should," I cannot shift into any other gears. If I push slightly out and to the right, and into third, and back into neutral, I am golden.
If the this a shift fork issue, or something more major? I cam running o.k. now, but expect the issue to become more worse. I would like to fix this now... input is greatly appreciated.
Thanx!
mojo_matic is offline
post #2 of 2 Old 05-21-2013, 08:39 AM Thread Starter
mojo_matic
1980 CJ5
No input??? I was thinking I just need to replace the forks...
