Synthetic Oil VS Regular Oil - Page 3 - JeepForum.com
post #31 of 37 Old 07-13-2007, 10:16 AM
blueknight44
30 years ago Mobil 1 full syn oil was rated for 25,000 miles before a need to change.
I change the oil filter every 3,000 miles and add one quart of new Mobile 1
blueknight44 is offline
post #32 of 37 Old 07-14-2007, 08:13 PM
JeepZJlover
ok let me explain myself a little more. I ran castrol full syntec and it ran hotter and louder with it then castrol 10w-30 with the lucas. I dont really care bout them bob the oil guy whatever my jeep is quiter and burns less with lucas and castrol together. soooo thats why i run it. maybe its not right or anyones cup of tea but it makes me happy so thats why i do it.
1993 Cherokee 4dr SE green, 4.0, Auto, HP30, 8.25, 3" lift 31" Goodyear Duratracs, Custom made front recovery bumper, Kenwood radio, 12" alpine type e subwoofer,alpine amplifier, Smittybilt xrc8 winch, tuff stuff portable winch receiver custom modified. 2002 Jeep Wrangler Sport 4.0, 5 speed, Dana 30 front, Dana 44 trac loc rear, Stock
JeepZJlover is offline
post #33 of 37 Old 07-15-2007, 12:06 PM
cowpie01
2006 KJ Liberty
I don't think anyone here will give you a load of grief over what you want to put in your engine. They are just pointing you to testing that has been done. I don't want to use it, but if Lucas was a terrible product that will cause things to fall apart sooner, it would not have a market very long.
Most oils are far and away sufficient for any user. Additives are not necessary except for special applications. Many additive companies are playing on our desire to get the most out of our investment. With vehicle purchases almost like buying a house now, it is easy to market items that make great claims.
It is possible that the Castrol you were using was not one of the best oils out there. Castrol makes some good products but have really dropped the ball in others. Comparison testing has shown that to be true. Heck, even the venerated Mobil 1 has flaws in some of the product line with other products being excellent. Unfortunately, the John Q. Public does not have the wherewithal to check out the testing and the desire to check them out in most cases. But if one is serious about it, there is good information out there regarding most oils.
In my case, I find it worthwhile to research a little on how oils stack up. My business and personal vehicles cost a lot of money. I want what works and will keep my farm tractor, semi, and Liberty CRD in top condition. But then, not everyone has a few hundred thousand dollars invested.
Environmentalist Green + Socialist Red = Facist Brown
cowpie01 is offline
post #34 of 37 Old 07-15-2007, 06:07 PM
JeepZJlover
hot dam you live in iowa hmm i ought to come see ya
post #35 of 37 Old 07-15-2007, 08:00 PM
Rocky.ca
I was hung up on whether or not to switch to syn. I decided for this oil change just to use valvoline maxlife dyno oil. I dont have the money to start dealing with leaks, and with around 110 000 miles on the engine already it is a very possible outcome. Maybe next summer, when i start working again i will make the switch.
Black 97 TJ SE 4bangin' away.
3" BDS lift
33" A/Ts
Sound System
custom de-milk jugged bumper :D
Rocky.ca is offline
post #36 of 37 Old 07-16-2007, 06:37 PM
CNY
Caught ridin' dirty
Originally Posted by Kyle Deidrick
......... if you have been running dino then stick with it as many people have made the switch and it has caused there seals/gaskets to leak because of the dino wearing off..........
Originally Posted by ZeroDormancy
from my research if you want to switch to syn its good to do a gradual change..........
I'm not a guy who is into spending the extra $ for synthetic, but it's amazing how a few stories spread into commonly accepted knowledge.
http://www.mobiloil.com/USA-English/...eage_Cars.aspx
There is simply no factual basis to this myth. You can switch to Mobil 1 synthetic motor oil at any age or mileage and, as long as the engine is in good mechanical condition, you should reap all the benefits that you would experience in a new car. In fact, switching a car from mineral oil to Mobil 1 at higher mileage can help reduce engine sludge and other harmful deposits that may have accumulated over the years.
BTW, I have always used whatever oil is cheapest, without regard to brand, mixing brands, mixing weights (10w40, 10w30)... oil changes anywhere between 4,000 to 7,000 miles. If I cared about having an engine last more than 250,000 miles, I might care more about the oil.
CNY is offline
post #37 of 37 Old 07-16-2007, 09:17 PM
gamble71
this is the way it was explained to me in my lubricants class for my A&P. Mineral oil will form sludge/deposits that will stop oil leaks. Synthetic oils clean up the sludge/deposits and the oil leak appears. Hence the reason so many people claim synthetics cause oil leaks. It doesn't destroy and gaskets/bearing materials or surfaces. I'm going to keep it in the jeep as long as I can, not sure how the 4.0 is on oil leaks. My ford 4.0 is quite the leaker, so mineral it stays
gamble71 is offline
What should I do for a regular Tune-up? cdduffman General Jeep & Off-Road Equipment 3 10-24-2008 06:17 AM
CB & regular 5mile 2-way Vrrooom Audio, CB & Ham Radios, GPS, & Electrical 4 12-25-2006 07:58 PM
floatation vs regular jaredakleiman Tires & Wheels 3 12-14-2005 10:49 PM
Should I go full synthetic or part or regular oil with a 4.0L 103k miles? TheJeepMan Engines & Drivetrain 3 12-20-2003 02:10 PM
Synthetic Oil to Regular Oil Problems! Big92Jeep Engines & Drivetrain 5 12-07-2001 12:05 PM
