#1 | |
Synthetic Oil
I will be changing to Synthetic oil this weekend. What is the best type to use for a 4.0 with 66k miles?
What are your thoughts on using slick 50 as well?
MiamiSahara 0lllllll0 2000 TJ 3.5" RE SF/ 2" BL D30/D35 4.56 Limited Slip Flowmaster Exhaust Warn Bumper 35" BFG AT |
#2 |
I run Mobil 1 full synthetic in both my TJ and the wife's KJ. It's all personal choice. I would stick with a recognized brand (Valvoline, Castrol, Penzoil, Mobil, etc.). Bottom Line: As long as you are performing regular changes, the engine will be fine.
Trombino -- '04 TJ -- Rubicon Express 4.5" Superflex + 3/4" Front Spacers, OME Shocks, Currie Rear Shock Relocators, JKS 1.25" BL, JKS BMML, JKS Quicker Discos, 15x8 Cragar Soft 8's, 35x12.50 BFG KM's, LoD Heavy Duty Rear Tire Carrier, Chopped Front Bumper, Uniden 520XL w/ 3' Firestik II, Skyjacker Steering Box Skid, Rusty's Engine Skid, IPF H4 Conversion w/ Fatboys, Hella 500 Windshield Driving Lights, Tomken Gas Tank Skid, ARB Rock Sliders, PSC Rock Ring (D30), Riddler (D44), MV50 OBA, Rusty's Air Tube, TBS, Flowmaster 40, Dana 44 with Trac-Loc, Warn XD9000i w/ Grill Guard The Wife -- '02 KJ Limited -- Pre-Lowered, Full Mopar Skids, 245/70-16 General Grabber AT2's, Trac-Loc Rear, Flowmaster 50 SUV |
#3 |
Teflon is for frying pans.
#4 |
i have a YJ and use the mobile 1 full synth high milage.
#5 |
Amsoil is very good.
#6 |
valvoline is probably the easiest to find around town. other wise amsoil or royal purple. mobil 1 would be near the bottom of my list
'00 Sport. 5-speed, Detroit TrueTrac Dana 44 rear, Detroit TrueTrac front, 4.10's, 2" RE BB, OME shocks, 31" BFG MT, JKS Quicker Disco's, Borla, Chicago Electric 10k winch '99 Z28 M6, some goodies '94 'Vette, A4 all stock |
#7 |
This has been covered over and over and over here. There are some answers regarding what is "best" however the question is what is "good enough".
Valvoline, Castrol, Pennzoil, and most others are Group III synthetics (not "true" synthetics. AMSOIL, Royal Purple, and Mobil1 are Group IV Synthetics (PAO Base Stock). Redline is a Group V synthetic (Ester Base Stock). There has been a lot of data via Used Oil Analysis that shows that Mobil1 causes more iron wear within the 4.0L motor than many other oils (including Havoline and Shell Rotella mineral oils). I use AMSOIL products exclusivly in my TJ. Stay away from Slick50. It is bad stuff. Many additives will do nothing but harm your engine. If you really feel the need to clean and flush your engine, consider Auto-Rx. Auto-Rx is a Group V Ester product and not a detergent or acid like many other products. If you really want to learn more about lubrication, start to spend some time at http://theoildrop.server101.com
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's) RedCell Motorsports http://www.myspace.com/redcellmotorsports |
#8 |
James is right, there was a post about this yesterday, guy asked the same question. Just to drop my HO in here, I'm running Redline if all my vehicles and ATV's, I find it's worked the best so far.
[FONT="Comic Sans MS"][COLOR="Blue"]That which does not kill us can only make us stronger, or cost us a lot of money! [/COLOR][/FONT] [FONT="Century Gothic"][COLOR="Cyan"]1998 TJ, 2.5" Skyjacker spacer lift, Rugged Ridge front bumper, S&B Intake, Poweraid TB spacer, Pacesetter Headers, Magnaflow cat and Dynomax exhaust. 31x10.5r15 Pro Comp Xtreme AT's on black Cragar Soft 8 15x8. Rockcrushers on the 30/35. RE hand throttle [/COLOR][/FONT] [QUOTE=FLATFENDER54]Arguing on the computer/internet is like the special olympics ................. even if you win your still retarded [/QUOTE] [FONT="Lucida Sans Unicode"][COLOR="RoyalBlue"]It's a Jeep thing, wait...what? I couldn't hear you![/COLOR][/FONT] [FONT="Comic Sans MS"][COLOR="Blue"]I wave too[/COLOR][/FONT] |
#9 |
So what....... the Group V is the best? Is the Grouping typically labeled on the bottle?
From the above post, I take it that Redline is the best? Does it cost much more? What are the oil change intervals? Thanks!
[SIZE="1"][COLOR="Blue"]Nicholas[/COLOR][/SIZE] ------- [COLOR="Blue"]Lock'd, Rock'd, but not ready to roll. [/COLOR] [SIZE="2"]There needs to be a Twelve Step program to stop the modding addiction![/SIZE] [SIZE="4"][B][COLOR="DarkRed"][U]SAVE PARAGON![/U][/COLOR][/B][/SIZE] Visit [url]www.saveparagonap.com[/url] to get more information. |
#10 |
Technically Mobil 1 is no longer a group IV, it is now a group III.
Andy '98 Jeep ZJ "Pearl" |
#11 | |
Group I Made through Solvent Freezing Group I base oils are the least refined of all of the groups. They are usually a mix of different hydrocarbon chains with little or no uniformity. While some automotive oils on the market use Group I stocks, they are generally used in less demanding applications. Group II Made through Hydroprocessing and Refining Group II base oils are common in mineral-based motor oils currently available on the market. They have fair to good performance in lubricating properties such as volatility, oxidative stability and flash/fire points. They have only fair performance in areas such as pour point, cold crank viscosity and extreme pressure wear. Group III Made through Hydroprocessing and Refining Group III base oils are subjected to the highest level of mineral oil refining of the base oil groups. Although they are not chemically engineered, they offer good performance in a wide range of attributes as well as good molecular uniformity and stability. They are commonly mixed with additives and marketed as synthetic or semi-synthetic products. Group III base oil products have become more common in America during the past decade. Group IV Made Through Chemical Reactions Group IV base oils are chemically engineered synthetic base stocks. Polyalphaolefins (PAOs) are a common example of a synthetic base stock. Synthetics, when combined with additives, offer excellent performance over a wide range of lubricating properties. They have very stable chemical compositions and highly uniform molecular chains. Group IV base oils are becoming more common in synthetic and synthetic-blend products for automotive and industrial applications. Group V Made various ways Group V base oils are used primarily in the creation of oil additives. Esters and polyolesters are both common Group V base oils used in the formulation of oil additives. Group V oils exhibit a wide variety of properties specific to each individual oil's formulation. Group V base oils are generally not used as base oils themselves, but add beneficial properties to other base oils.
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
