#1 | |
Synthetic Oil
I recently bought a 2006 Wrangler 4.0L (3500 mi) and am thinking of switching to synthectic oil.
Does this make a significant difference in engine life? How often do you change this oil? Best type to get? This would be the first time using this type of oil so please respond with any tips. Thanks
#2 |
You will get a million different answers to your question. I can offer the following facts that are hard to argue with: AMSOIL, Redline, and Royal Purple are very high quality synthetic lubricants made from PAO base stocks. Mobil1 is now formulated using Group III base stocks. Mobil1 is known to produce high iron wear in the Jeep 4.0L motor. The only way to determine proper drain intervals using a high quality oil is to perform regular used oil analysis.
Check out http://theoildrop.server101.com and start to make some of your own decisions. My personal decision has been to run AMSOIL 0w-30 in my 2004 2.4L TJ since new and AMSOIL 10w-30 in my V-8 CJ. I am currently working on a 10,000+ mile oil change interval based off of Used Oil Analysis from Blackstone Labs.
*2004 TJ (Mine)* 1984 CJ-7 Buggy Project (Mine)* 1977 CJ-7 (Hers)*2005 Nylint Crawler (The Kid's) RedCell Motorsports http://www.myspace.com/redcellmotorsports |
#3 |
Definatley put some more miles on it first to break in the motor properly. Ive heard this from others on this forum. Id say swap at 15K.
#4 |
I switched at ~6mo/5k miles. I've been using Amsoil XL7500 5W-30 in the winter, and 10W30 in the summer changed every 6mo/5k miles. I haven't done any testing, I just change it every 6 months.
'03 Bright Silver Metallic TJ Sport BSMCCEP Club Member #45 Stock: 4.0L I6:5-speed:3.07 gears:D35 with Trac-Loc:15x7 Ecco wheels:Dual Top Group Mods: 30x9.5 BFG A-T T/A KO's:JKS Quicker disconnects:Rock-It Man rocker guards:Jeep Medic oil pan/tranny skid:Kilby steering skid:Warn D30 diff guard:C4x4 D35 diff guard:Rusty's radiator guard:Skid Row LCA skids:SilverStar headlights and fogs:Hidden Hitch class III receiver:Old Realistic 40ch CB:2' Firestik II:Arizona Rocky Road tailgate antenna mount Next : Jeeperman rear bumper '06 Candy Orange Honda Shadow Spirit 750 |
#5 | |
#6 |
Thank you for the feedback.
I am going to do some more research, but right now I am thinking at 5k of going to Amsoil 10w30. |
#7 | |
Syn oil will run your lube functions better. In many cases the engine will run slightly cooler. But then again the dino oils they have today are really good products. The big advantage of syn oil is an extended service life as it does not break down as quick. I run mine as long as 7-8 miles in my car and pickup. On the Jeep it'll depend on my dust conditions. If you run in extreme dirt oil changes need to be more often. If you plan on running syn oil and changing oil every 3000 miles the usefulness of syn is wasted IMHO. Just go dino oil in that case.
2006 Solar Yellow Rubicon Unlimited Jeep Club Member #1340 6 Speed, Hardtop Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come! |
#8 |
I ran dino Chevron 10w30 for the break-in on my 4.6L stroker, now I'm running Amsoil 10w30, from what I can tell it's a high quality group IV synthetic. Not the XL version, the high performance rated one, yellow/orange label, now looks like it's re-done to a white/bluish label. I'm running Amsoil for all lubricants, in all my vehicles. It's also readily available in my small town, so it's cheaper for me than Mobil, Castrol, or any other synthetics.
Always had great luck with Amsoil, no need to change. By the spring I'm installing my Amsoil Bypass filter system, should have a 10-11 quart crankcase capacity then, good for 20-25,000 miles.
'04 Rube JEEPS ARE NOT CARS, STOP CALLING YOUR JEEP A CAR!!!!!!!! |
#9 |
oops, double post.
#10 |
Alot of new vehicles come with synthectic in the motors from the factories, BMW, Mercedes Harley Davidson to name a few. I use Amsiol and like it.
#11 |
Amsoil is the way to go! But then again, I am an Amsoil dealer....
2000 Volvo V70 XC SE 2004 Nissan Armada SE Off-Road |
#12 |
I'm switching to Royal Purple at about 5200 miles. I got a 4.7 so probably not to much of a difference, except in extreem coold weather, but it sure won't hurt it.
[SIZE="3"][FONT="Comic Sans MS"][COLOR="Olive"]Bryan[/COLOR][/FONT][/SIZE] [FONT="Book Antiqua"][SIZE="1"][COLOR="olive"][COLOR="YellowGreen"]"Some people are like slinkies... Not really good for anything, but you still can't help but smile when you see one tumble down the stairs.”[/COLOR][/COLOR][/SIZE][/FONT] |
#13 |
Amsoil is great. I just switched about 6k ago. I got 88k on my 98 tj. Barely burned any oil. Check out their oil filters too and in JP magazine this month they feature Amsoil with new products.
#14 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
