Swapped out the automatic transmission for a manual and now i dont have any spark - JeepForum.com
post #1 of 3 Old 10-27-2013, 04:47 PM Thread Starter
jmcvay
I have a 1997 TJ and i just swapped in a AX15 transmission. I hooked up all the plugs that i could on the new tranny but there are a couple that there is nowhere to plug them in. When i turn my key on it wont turn over and when i jump the starter with a screwdriver i have no spark Any help would be greatly appreciated!
jmcvay is offline
post #2 of 3 Old 10-28-2013, 07:30 AM
LaddieHanus
There is a round plug that was on the drivers side of the automatic transmission. This has a wire that tells the computer and starter relay that the trans is in neutral or park to let the starter run. You are going to have to ground it. You will also not have any backup lights as the reverse switch is in the same plug.
And if you have not changed the engine computer to one from a manual transmission you will have a check engine light as there is no torque converter and the computer will throw a code when it tries to lock it up.
The Nss connector wires are
CAVI CIRCUIT I FUNCTION
1 I L1 18VT/BK I BACK-UP LAMP SENSE
2 I T41 18DG/YL I PARK/NEUTRAL POSITION SWITCH SENSE
3 F20 18VT - ~ FUSED IGNITION SWITCH OUTPUT (RUN)
Laddie Hanus
2009 JKU Rubicon
97 TJ Sahara
89 YJ
2000 Dodge/Cummins Lance Camper
2004 GC Limited (Wife Jeep) 4.7 HO rebuilt 9/2016
LaddieHanus is offline
post #3 of 3 Old 10-28-2013, 06:58 PM Thread Starter
jmcvay
Okay I grounded the neutral position sensor wire, and it will turn over now but I still don't have any spark. Any ideas on that?
jmcvay is offline
