swap something into a 98 TJ SE? - JeepForum.com
post #1 of 9 Old 07-15-2005, 09:54 AM Thread Starter
CoriolisSTORM
WHAT?!
CoriolisSTORM's Avatar
2010 JK Wrangler
Okay, I figured this kinda goes here instead of the TJ Tech forum. So, I'm looking at something to replace my 2.5L I4 with. Any ideas on something that's easy to find and has good aftermarket support and is good for offroading? I'm kinda thinking the 5.2L or 5.9L out of a GC might do pretty good, as the 4.0Ls are too hard to find around here. Is there a better engine or idea that you can think of? I kinda want something that has good low end torque and HP making it good for offroad. I searched a while for a Cummins, but that's too heavy I think, requires too much drilling and frame reinforcement, and is way too expensive. Ideas please. I would like the 5.7L Hemi conversion done, but that's just a rediculous ammount of power and money.
1998 TJ Wrangler SE - Stone White, 2.5Ls of screaming lifter clacking power, AX5, 31" BFGoodrich All Terrain T/A KOs
2010 Wrangler Unlimited Sahara - Deep Water Blue, 3.8Ls of oil consuming fury, NSG-370, BFGoodrich Rugged Terrain T/A 265/70/R18s
CoriolisSTORM is offline
post #2 of 9 Old 07-15-2005, 06:48 PM
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
How about a dodge neon head,turbo and intake swap for your four banger. I think they are the same basic engine (below the head). I'm sure I'll be corrected if I'm wrong.
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline
post #3 of 9 Old 07-15-2005, 07:20 PM
green cj 78
1978 CJ7
thats a good idea, it wont turn heads till the turbo spools up.
78 CJ7
5.3 Vortec, T18, Dana 20, AMC 20, Dana 30
97 XJ 2wd POS.
green cj 78 is offline
post #4 of 9 Old 07-16-2005, 08:06 PM Thread Starter
CoriolisSTORM
WHAT?!
2010 JK Wrangler
That's an interesting idea. How much should it run me? Does a Neon come stock with a turbo or do I need to order one from somewhere?
post #5 of 9 Old 07-17-2005, 11:54 AM
sboyd16
the new srt4 comes with a stock turbo, u would prob be the only one around with the setup
sboyd16 is offline
post #6 of 9 Old 07-17-2005, 01:07 PM
ZR7 Ken
ZR7 Ken's Avatar
I'm not 100% sure, but I believe you may be thinking of the 2.4 liter 4cyl that comes in newer TJs. He has the 2.5, which is the same type design as the 4.0.
ZR7 Ken is offline
post #7 of 9 Old 07-18-2005, 05:37 PM Thread Starter
CoriolisSTORM
WHAT?!
2010 JK Wrangler
Yep, I was thinking about that too. The 2.4L in TJs now is from a Neon. The 2.5L in my older TJ is from AMC and goes back to one similar to the old GM Iron Duke. However, is there anything else that uses the AMC/Chrysler 2.5L that has a turbo?
post #8 of 9 Old 07-18-2005, 05:53 PM Thread Starter
CoriolisSTORM
WHAT?!
2010 JK Wrangler
oops. Ignore this one and go on down some.
post #9 of 9 Old 07-18-2005, 05:55 PM Thread Starter
CoriolisSTORM
WHAT?!
2010 JK Wrangler
Well, the 2.5L did have a turbo at one time. What do you guys think? Think it'll be hard to find one? http://www.allpar.com/mopar/22t.html
I think it'd be worth it if I could find one and rebuild it before placing it in, but will it fit on my '98 model 2.5L I wonder? Would Pirate 4x4 or some other place have an idea?
I6 to V8 swap - Direct swap? tawdr77 Engines & Drivetrain 2 01-17-2010 10:35 AM
Will my 258 engine swap..... swap? Toady1 Engines & Drivetrain 1 11-09-2009 08:08 AM
8.8 swap CreepyCrawler95 Engines & Drivetrain 2 03-22-2009 08:06 PM
AMC 360 swap flashfludjr Engines & Drivetrain 1 03-22-2009 10:50 AM
Help...D44 to 60 Swap ADay73 Engines & Drivetrain 1 08-22-2007 06:17 PM
