supercharger 4.0 - JeepForum.com
post #1 of 11 Old 10-28-2008, 06:02 AM Thread Starter
travail
supercharger 4.0
So does any one on the forum have a supercharger 4.0. I plane on making my own set up with a supercharger off of a 3.8 Thunderbird. I am using a 99 XJ intake manifold and part of the lower manifold off the Thunderbird to make it work. The Thunderbird supercharger should work.
travail is offline
post #2 of 11 Old 03-03-2009, 04:15 PM
gravity
did you ever get anywhere with this kinda thinkin the same
gravity is offline
post #3 of 11 Old 03-03-2009, 05:30 PM
spyder6
Got that Toyota chit
spyder6's Avatar
2010
thats going to be a lot of work. there are a couple companies like RIPP and Avenger that make kits. no one on here has made their own supercharger system. Air Sierra made his own turbo setup on his 2.4L though.
you're going to need some sort of piggyback computer and a dyno to get it to work right!
My builds:
and
or follow us on
spyder6 is offline
post #4 of 11 Old 03-03-2009, 07:54 PM
Cutlass327
Cutlass327's Avatar
1978 CJ5
I know some have taken the ECU from the 2.5T cars and wired them up to non-Mopars to power their Ford 2.3T. Why not get the T-bird ECU and wire it to the Jeep's 4.0? I doubt the 0.2L difference would make much difference. Plus I know they make tuners for the Ford EEC-IV and OBDII ECU's, so just tune it with a WB O2 and go from there.
My question though, how similar is the internals of the 2.5T to the 2.5 in the Wranglers? Would the forged pistons swap in? I imagine the mounts and such of the FWD turbo engine wouldn't allow you to just drop it in to the RWD.
Cutlass327 is offline
post #5 of 11 Old 03-04-2009, 12:15 PM
jeepster3495
There is a company that makes a supercharger kit for 2 different engines. There called Ripp Modifications. There centrifugal S/C as apposed to roots style. Basically a belt driven turbo.
http://www.rippmods.com/Supercharger..._CARS_s/20.htm
Hope this might help someone who is looking for a S/C setup.
jeepster3495 is offline
post #6 of 11 Old 03-06-2009, 07:50 PM
Reelm n Rubi
Fish fear me
Reelm n Rubi's Avatar
Why supercharge a Jeep?
2003 Lt. Khaki Rubicon automatic
Supercharged 4.7 stroker w/ Hesco aluminum head
70mm F&B throttle body
Kieth Black forged 944 pistons
Comp Cams custom ground camshaft
505 Performance PCM
Split Second Engineering fuel/timing management
Tom Woods CV driveshaft
50 lb/hr Trick Flow injectors
4" Full Traction LA with Bilstein 7100's
JKS 1" MM,BL. TeraFlex engine and steering armor
4.88's w/ 35 " Toyo Open Country m/t's
Moser Chromoly axle shafts front, Superior D44 rear
Warn 9.5ti on a M.O.R.E hi clearance bumper
Reid racing knuckles, Warn premium hubs
PIAA 525's, and 510's
XBOX Gamertag- ISHAGDyurGURL
For SALE-- standard drop pitman arm redrilled with new 1 ton GM tye rod end (bottom mount). Perfect $30
Reelm n Rubi is offline
post #7 of 11 Old 03-06-2009, 09:23 PM
scrapinrocks
Homemade turbo kit on my YJ
scrapinrocks is offline
post #8 of 11 Old 03-07-2009, 05:58 AM
Happy Joe
To get the same performance at 10,000 feet as you can get at sea level...
There is a very substantial difference.
Enjoy!
...a well prepped, well driven, vehicle should do well in any terrain, including the highway.
Carburetors became obsolete during the last century... do what ever it takes to get fuel injection...It makes bigger grins off road.
Happy Joe is offline
post #9 of 11 Old 03-07-2009, 08:38 AM
spyder6
spyder6's Avatar
2010
Enjoy!
reelem in rubi actually has a 4.7L stroker, hesco aluminum head and a avenger supercharger. his jeep will lift the front wheels off the ground. hes just messing with you
My builds:
and
or follow us on
spyder6 is offline
post #10 of 11 Old 03-07-2009, 09:02 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Enjoy!
read his profile and signature.
hes probably pulling 400-450hp out of his 4.0L
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #11 of 11 Old 03-07-2009, 11:45 AM
Happy Joe
I missed the supercharged part at first glance.
I figure a simple question needs a simple answer...
Enjoy!
which supercharger to buy codretaw1 Engines & Drivetrain 2 02-02-2010 05:18 PM
supercharger? eclipse27 Engines & Drivetrain 8 06-11-2008 03:08 PM
Supercharger RogueXJ Street Jeep Forum 18 02-19-2008 07:16 PM
242 Supercharger Eagle Kammback Engines & Drivetrain 2 12-02-2007 04:35 PM
M90 supercharger gbaronetXCR Street Jeep Forum 1 01-26-2007 07:38 PM
