stuck valve? - JeepForum.com
post #1 of 5 Old 10-17-2001, 04:41 PM Thread Starter
Paul Ank
stuck valve?
Thanks for taking a look.
I have a '94TJ 4.0L. Just recently the engine started making a knocking noise. The noise starts when the engine is cold and will last for about 3-5 mins before it quits, then the engine sounds normal. I've been told that it may be a sticking valve. The valves have always sounded loud (I've owned it for 6 years)I tried to take it and get an oil change, but the local "Jiffy Place" said they won't touch it with noisey valves. What can I do?
Thanks again for any advice...
Paul Ank is offline
post #2 of 5 Old 10-18-2001, 08:33 AM
CHVYPWR
Well, you could always change it yourself.
-1985 XJ. Trail beater in the making.
-'04 GMC Canyon SL 4x4
CHVYPWR is offline
post #3 of 5 Old 10-18-2001, 08:27 PM
Brendan
Dude, if you know what the valves sound like, then you should be able to change your own oil, it takes 5 minutes if your good, and is actually kinda fun. If they are still loud take off the valve cover, and see what you find.
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #4 of 5 Old 10-18-2001, 08:29 PM
Brendan
PS there is no such thing a 94 TJ. TJ's are 97+ wranglers. If your jeep is a wrangler, you've got a YJ. Just to let ya know.
Duvie
95 YJ 2.5L 5 Speed
Brendan is offline
post #5 of 5 Old 10-18-2001, 10:21 PM
evilpsych
evilpsych's Avatar
heh.. there are a few solutions you can try.. Anytime my dad and a few other guys have had noisy valves/lifters etc.. they've added some ATF to their oil before they change it.. they run it a bit and the ATF foams and cleans the valves.. you can always get a can of motor flush also and do the same thing.. after you've done this i suggest mobil 1 Drive Clean blend.. I've also had good luck with Z-max additive in cleaning deposits..
A
So he wants to go OFF-ROAD does he????
'93 YJ, 4.0, K&N filter, Borla Header, Borla Cat-Back, Hi-Flo Cat, 3 Core Radiator, D-Rings, TruckNuts, MSD 6A, LockRite Locker in D30, Magnecors, Kickass Stereo, 1" daystar, 31" BFG AT's, Homemade Rocker Guards and Front/Rear air-tank bumpers with tire carrier, 15x8 AR-767 4"BS, BDS 3.5 HD lift, AMA A/C Kit, York OBA, GoFerIt 1" MML, 8,000lb HF/MM Winch, Magellan MAP 330 GPS, PRO-2067 500ch. Scanner, oh, and a CB capable of talking to SATURN!
"The Only Thing Necessary for Evil to Succeed is for Good Men to Do Nothing." - Edmund Burke
evilpsych is offline
Do I still need my EGR valve? gmgreen Engines & Drivetrain 46 09-21-2009 05:49 AM
Leaky Valve Stem - Gorilla Flush Mount Valve the Answer? Jeepin72 General Jeep & Off-Road Equipment 6 06-03-2009 01:28 AM
valve tap? ferger Engines & Drivetrain 1 10-04-2007 02:51 PM
pcv valve in a 98 tj? genakab Engines & Drivetrain 2 02-24-2006 03:24 PM
what causes a valve tap? OlllllllO Engines & Drivetrain 3 08-25-2004 05:39 AM
