Stuck need help - JeepForum.com
post #1 of 5 Old 12-07-2013, 08:38 PM Thread Starter
seanwilliams4
Stuck need help
Got a few question with installing new clutch. When you have your pressure plate installed should you be able to have some play with your clutch plate. And how do you realign your transmission spline so your tranny is hooked back up on your engine?
seanwilliams4 is offline
post #2 of 5 Old 12-07-2013, 08:52 PM
jokerchief462
The clutch kit should have come with a plastic alignment tool. If not stop where you are and get one.
Once the pressure plate is installed and torqued there should be no play in the clutch plate it should be stuck in place between the flywheel and the pressure plate.
Sent from underneath my Jeep
89YJ 2.5L TBI, AX-5, NP231 SYE, Ford 8.8, Yukon Grizzly, Tom Woods Shaft, 33" BFG T/As, 4" lift, Warn VR10000s.
AF Jeep Club Tail #184
jokerchief462 is offline
post #3 of 5 Old 12-08-2013, 02:28 AM
jnicewan
^ like said above, only to include that the alignment tool (usually plastic and supplied with clutch kit) should be installed before you tighten the pressure plate down. You will have a little wiggle with the alignment tool and thats normal, you want to just try and center the alignment tool in the "play" of the disc before tightening down the plate.
jnicewan is offline
post #4 of 5 Old 12-08-2013, 06:41 AM Thread Starter
seanwilliams4
Okay I used my alignment tool and tighten the pressure plate with it still in. So if done correctly the clutch disc won't be able to move inside of the pressure plate?
post #5 of 5 Old 12-08-2013, 06:42 AM
Mean Max
Don't poke the bear
Mean Max's Avatar
Correct.
Max
Originally Posted by UltimatE View Post
Max has a picture of every Jeep part ever made.
Originally Posted by Benderff View Post
No one here knows what they are talking about. You should try Pirate 4x4 they will be happy to help you.
There is no situation that cannot be improved with a small but well-placed explosive.
Mean Max is offline
