Stroker buildup. - JeepForum.com
post #1 of 4 Old 02-08-2006, 01:10 PM Thread Starter
Mateo94XJ
Stroker buildup.
Hey guys, maybe you can help me. The 4.0 is shot in my XJ, thanks to years of neglected maintenance by the original owner. I found a motor to drop in for the meantime, and I can take the original motor out and rebuild / stroke it.
Sicne the 258 and 242 are so closely related, could I buy a master rebuild kit for a 258 and then put it into the 242?
Are the cams any different in these two motors (my gut says yes)?
LET THE DISCUSSION BEGIN.
'94 XJ Sport 2dr.
'86 MJ
'42 Willys MB
Mateo94XJ is offline
post #2 of 4 Old 02-08-2006, 05:15 PM
gumcrew2
1991 XJ Cherokee
I wouldn't be a master rebuild kit because you can do it cheaper than those kits. I built a high budget stroker but here's a break down of how to build a good cheap stroker
4.0L engine (you already got one)
258 crank, comes with rod and main bearings ($300 shipped on ebay)
258 connecting rods ($125 shipped on ebay)
piston rings ($50 shipped on ebay)
gasket set ($75 at autozone)
have a shop press the pistons to the rods ($50)
that's it, if you were to spend more, I would recomend getting the block bored, you can get a set of new pistons on ebay, in almost any overbore size, for $150 shipped
after that I'd get a cam and lifters, you will probably need new valve springs though.
o yea, get the cam bearings replaced, pay a shop to do it, it's a PAIN in the ***.
I have no idea if they had different cams.
"Nitrous? So is that like viagra for your Jeep?" -mom
"I flopped it"
gumcrew2 is offline
post #3 of 4 Old 02-08-2006, 07:43 PM
Bgeddes
Bgeddes's Avatar
1978 CJ5
Check out:
http://www.jeep4.0performance.4mg.com/stroker.html
Everything from simple to crazy.
As far as finding a 258 crank and rods, my local U-pull-it sells complete motors for $100. I am planning on buying 1 each 4.0 & 258 for my stroker build. I believe your best bet for a master rebuild kit would be the 4.0 HO. You will need to let the machine shop clean and check your 4.0 block & 258 crankshaft prior to ordering the kit. You might need oversized pistons and or bearings. The strokers pretty much straight 4.0 parts except for the crank and rods. Lots of cam options, one of setups on the page above uses a stock 4.0 HO cam, and late model injectors.
'00 XJ Classic > Stock DD
'88 Grand Waggy - Bone stock pseudo-barnfind
'78 CJ5 - Under minor rehab
Bgeddes is offline
post #4 of 4 Old 02-09-2006, 12:41 AM Thread Starter
Mateo94XJ
Oh I know that doing cam bearings is a complete pain, been there tried not to do that. It's real nice when you have the tools.
I hadn't thought about buying a u-pull-it motor and running that, that's interesting.
I know I'm going to have to do machine work on my 4.0 block, this one is dying (leaking like a sieve and very low compression on cyl 5&6) due to probably broken rings, so at the least an overbore and hone would be needed. I've got a good reputable shop to do the machine work, so that takes care of that.
Thanks for steering me away from the master rebuild kit, I now understand.
'94 XJ Sport 2dr.
'86 MJ
'42 Willys MB
Expedition TJ Buildup thejafe General Jeep & Off-Road Equipment 38 08-25-2008 10:13 PM
8.8 buildup question Spectre66 Engines & Drivetrain 0 02-15-2007 06:15 AM
Street Jeep Buildup spitfirees20 Street Jeep Forum 72 08-21-2006 07:13 PM
XJ D44 buildup and install thephantum Fabrication Shop 4 06-22-2004 09:39 PM
Buildup Springs Briznett Tires & Wheels 3 01-29-2004 12:48 AM
