strengthen my axle - JeepForum.com
post #1 of 11 Old 09-23-2007, 07:29 PM Thread Starter
airframer
airframer's Avatar
strengthen my axle
hey i have a tj i am about to lock my d30 and d44 and 33's if i wanted to strengthen my axles anyone have any suggestions??
Everything in moderation
airframer is offline
post #2 of 11 Old 09-23-2007, 07:44 PM
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
chromo shafts if your looking to upgrade the shafts. you could truss it if you are looking to upgrade the housing
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #3 of 11 Old 09-23-2007, 08:13 PM Thread Starter
airframer
airframer's Avatar
mainly i just dont want nethin snappin on the trail, even tho i ve been told that i should b fine being that i am not running xtremely large tires but better safe than sorry
post #4 of 11 Old 09-23-2007, 08:38 PM
elkfan2
elkfan2's Avatar
Chromoly Axles
elkfan2 is offline
post #5 of 11 Old 09-24-2007, 09:58 AM
ovrszd
Depending on your driving style, it's very possible you will break a rear axle and more than likely you will break a front axle joint which will explode the factory axle in the process. The front failure will happen much quicker with a locker installed. The rear will happen from abusing it by slamming a tire into a good traction object while spinning.
Chromoly shafts at a minimum. Upgraded front axle joints if funds are available. I installed Alloy X joints with my shafts and have since replaced them with CTMs because the X joints failed. I'm on 37" tires but running 4.10 gears.
The skies the limit, or I should say the wallet is the limit!!!
Stock Jeeps Worry Me
ovrszd is offline
post #6 of 11 Old 09-24-2007, 11:18 AM
JeepRocks86
i'm running yukon chromos and spicer U joints up front because of the budget.
I have a set of alloy USA shafts awaiting to go in the rear. I twisted one of my 44 rear shafts a little.
For Sale:
post #7 of 11 Old 09-24-2007, 11:29 AM Thread Starter
airframer
airframer's Avatar
since ive posted this thread ive been looking into shafts, i am assuming the the higher the spline count is the stronger the axle?
post #8 of 11 Old 09-24-2007, 12:39 PM
ovrszd
Yes. Axle splines are machined the same size per spline. So the more splines, the larger the diameter of the shaft. You cannot change spline count without making changes inside the carrier. If you are adding lockers and haven't bought them yet you can shop for lockers with larger spline count. But in the front you will be limited by your front bearing hub assembly unless you go crazy and add a hub conversion. Again, the wallet is the limit.
ovrszd is offline
post #9 of 11 Old 09-24-2007, 05:03 PM Thread Starter
airframer
airframer's Avatar
o that makes sense, the highest sc ive seen is 33, so by increasing the spline count i increase the diameter of my axle.
post #10 of 11 Old 09-30-2007, 07:28 AM
TSEJEEPERS
Randy's ring and pinion has a upgrade for the Dana 30. 30 spline shafts with a ARB. A buddy of mine runs them and has broken at least one. This is with 35 inch tires. Not real sure if it is worth it or not. Here is a picture of the shaft.
93 YJ SOA 2" springs front, XJ springs rear w/main leaf added, High pinon 9 inch rear detroit locker front Dana 44 ARB 4.56 Gears, 36 inch Irok tires too much to list.
TSEJEEPERS is offline
post #11 of 11 Old 09-30-2007, 07:32 AM
TSEJEEPERS
Oh these are Yukon chromoly shafts. After he did it we just said maybe we can find one in the junkyard and throw it in. Then we remebered they were 30 spline. Randy's did replace the axle shaft as I think they have a 3 year warrenty and this axle was less than a year old.
Superior Axle and Gear Super 35 Axle Trusses pfifer Engines & Drivetrain 1 04-15-2009 02:34 PM
2wd Rear Axle to 4wd Rear Axle Swap awilkie Engines & Drivetrain 1 01-20-2009 12:49 PM
best way to strengthen frame mrbigglesworth Fabrication Shop 9 12-09-2006 07:05 PM
What to use on axle? JSBlu974X4 General Jeep & Off-Road Equipment 6 10-14-2006 07:54 PM
axle? classof04 General Jeep & Off-Road Equipment 1 06-03-2003 09:15 PM
