Strange noise from rear axle - JeepForum.com
post #1 of 2 Old 05-21-2008, 09:11 AM Thread Starter
TEXASRAM
TEXASRAM's Avatar
Just started yesterday, while jeep is rolling, starts, progresses with speed, sounds like small bearings rolling around in can. Did notice a little while back some kinda oil stain on my drivers side rear wheel. is it a busted seal? how difficult to repair?
1995 JEEP Wrangler, 4.0 H.O. , IL6 4x4, White/Spice, Auto, Custom Center Console, Homemade Cold-Air Intake, 31x10.50x15 MT, Rubicon fenderflares, Black Denim Bestop Supertop, FlowMaster Exhaust, Hi-Flow Cat, 2" Performance Accessories Body Lift, Custom front bumper
homemade xtras to come.... rear bumper w/ tire carrier, rock sliders.........
"DON'T MESS WITH TEXAS"
TEXASRAM is offline
post #2 of 2 Old 05-21-2008, 09:22 AM
Nwjeeper
Had the same thing on our TJ, ours had a groove worn in the axle shaft by the axle bearing (which is located at the end of the tube just behind your brake drum) and the deflection due to the loss of material caused the shaft to push the oil seal out of the way and start leaking oil.
If you do need to replace the bearing you have to pull the axle shaft on that side to be able to get the bearing and seal out. A slide hammer is a huge plus for this job. We found out after doing ours that NAPA has special replacement bearings that can be used that will come to bear on a different spot on the axle shaft so that you don't necessarily have to replace the shaft. In our case we had a spare shaft so we just replaced the bearing, seal and the shaft.
Good Luck.
Ed
The Trail Starts Here!
I can fix it and if I can't fix it, I can fix it so no one can fix it!
Nwjeeper is offline
Strange front end noise flexsaharatj General Jeep & Off-Road Equipment 1 07-12-2009 01:58 PM
strange noise jbjeepin Engines & Drivetrain 4 11-05-2008 02:07 PM
Strange noise from front-end.. Runnerboy Tires & Wheels 7 07-05-2006 09:36 AM
Strange noise DroopyDog Audio, CB & Ham Radios, GPS, & Electrical 4 08-19-2005 07:03 AM
RE 5.5 LA with strange noise Ned97sahara Tires & Wheels 1 07-15-2003 08:32 PM
