straight 6 head gasket blown. need help - JeepForum.com
post #1 of 13 Old 06-26-2011, 01:51 PM Thread Starter
golfhunting6
does any body kno of any websites or videos online that would show me or help me with replacing a head gasket in my inline 6 engine. i have all the new parts but have no clue what i have to do or how to do any of this. i need my jeep working so i can work my self someone please help thanks
golfhunting6 is offline
post #2 of 13 Old 06-26-2011, 01:52 PM
iDriveYJ
do you have a service manual?
iDriveYJ is offline
post #3 of 13 Old 06-26-2011, 02:05 PM
greyarea
Get a Haynes manual from the parts store. They give a step by step.
90 YJ Magnum 5.2 v8 , 1'' BL, 1'' booms, 4" Procomp, 35/12.50-15 MTR/kevlar Ford 8.8 4.10 lsd Aussie and TJ shafts up front.
KI4UTU
greyarea is offline
post #4 of 13 Old 06-26-2011, 02:08 PM Thread Starter
golfhunting6
yea i have the haynes but it doesnt explain how to do the head gasket in it
post #5 of 13 Old 06-26-2011, 02:10 PM
99TJSahara
http://www.jeepforum.com/forum/f140/...cement-598875/
-Joey
04 Grand Cherokee Overland
-sold
99TJSahara is offline
post #6 of 13 Old 06-26-2011, 02:12 PM Thread Starter
golfhunting6
im pretty mechanicaly inclined but dont kno much bout engines and a friend was suppose to help me but he broke his foot and cant help for a while but i need jeep running by tomorow o wed at the latest
post #7 of 13 Old 06-26-2011, 02:30 PM
99TJSahara
What jeep are you working on? year? model?
Also this it is a rather simple job but if you don't know what your doing I would find someone who does (better to do it once with help, than do it twice with help the second time)
Heres a short version:
disconnect battery
remove serp. belt
drain coolant
remove intake and exhaust manifolds
remove upper radiator hose, heater hoses and t-stat housing
remove valve cover and valve cover gasket
Remove rocker arms and pushrods(make sure they stay in order and go back exactly where they came from)
Loosen the head bolts and remove the head
remove the old head gasket
Clean up the head to block mating surface and try and keep dirt out of the cylinders.
Remember to torque the head bolts in their proper steps and patterns
reverse steps for install
Once its back together change the oil and filter before you start it
-Joey
-sold
post #8 of 13 Old 06-26-2011, 02:46 PM Thread Starter
golfhunting6
96 jeep grand cherokee laredo zj inline 6 4.0L 150,400 miles
post #9 of 13 Old 06-26-2011, 03:34 PM
wushaw
Rockin jeep
wushaw's Avatar
If you need it tomorrow then you better get cracking. Good luck on having it done by tomorrow for the first time to ever do this job.
wushaw is offline
post #10 of 13 Old 06-26-2011, 05:38 PM
4G64
+1
I'm not 100% sure, but are Jeep heads aluminum? You may have to get it re-surfaced. I've replaced blown HGs before without re-surfacing the head, only to take everything apart because I skipped that step.
4G64 is offline
post #11 of 13 Old 06-26-2011, 07:37 PM
wushaw
Rockin jeep
wushaw's Avatar
The jeep head is steel but that does not mean they will not warp.
wushaw is offline
post #12 of 13 Old 06-26-2011, 08:12 PM
circa27
I had a cracked head and blown gasket, my oil was cream colored from all the leaked coolant. I realize bragging about a product with only 3 posts makes me look like a spammer but I'm not haha. This stuff made by Rislone (there are tons that all say "head gasket block fix") but its in a tall grey opaque bottle, you run it in your coolant for 30 mins with the heater on full and then change your oil. Top up the coolant, let the Jeep cool. Its fixed.
Now I know youre all going to say "its temporary, they all say that" and I assumed the same but I paid 120 for this stuff before it came to Canada because I saw it on powerblock tv haha. Its been sealed and I've had clean oil since October.
Just my $0.02
circa27 is offline
post #13 of 13 Old 06-30-2011, 06:55 PM
motoman225
Just my $0.02
I had that in a Cadillac that had blown head gasket. I drove it for 8 months like that then I blew the motor suddenly with no warning because it dumped all the coolant when the sealant came out. Don't make my mistake. Fix it correctly. That stuff is a temp fix.
motoman225 is offline
Blown head gasket or ? mtngoht Engines & Drivetrain 7 06-14-2008 11:09 AM
head gasket blown, have questions badoosh27 Engines & Drivetrain 13 10-31-2007 05:28 PM
how do i know if my head gasket is blown? badoosh27 Engines & Drivetrain 8 08-17-2007 03:30 AM
I have a blown head gasket JeepPilot Engines & Drivetrain 7 06-30-2006 12:58 PM
Blown Head Gasket, need advice Valermos Engines & Drivetrain 8 04-07-2006 02:52 PM
