Steering Shaft Question - JeepForum.com
post #1 of 5 Old 05-13-2014, 04:42 PM Thread Starter
becraftj2286
1983 CJ8
Hello everyone,
My mechanic has been working to tighten up my steering and he said that the steering shaft on my Scrambler is too short. The Jeep has probably 5-6 inches of lift on it. I didn't do the lift, I just bought the Jeep about 3 months ago and trying to work out all the bugs. The steering is very loose. My mechanic says the steering shaft has reached its telescoping limit and needs to be extended or replaced with a longer one. Has anyone heard of this issue? What can be done to correct it? When I look on quadratec.com, their steering shafts don't say anything about different lengths. Please let me know what you recommend is needed to correct this.
thanks!!!!
John
becraftj2286 is offline
post #2 of 5 Old 05-13-2014, 07:00 PM
BlueRubiconrich
5" to 6" of lift. How?
leafspring lift
and shaklelift
and body lift. Only body lift with effect the shaft.
Rubicon Rich ,05 TJ Rubicon: PatriotJeepers.com
86 CJ7 258,T18,Scout Dana300,twin sticks,Dana44's,4W Disc, locked,35's,YORK OBA,Warn 8274,fullcage.
51 M100 1/4 ton Jeep trailer
BlueRubiconrich is offline
post #3 of 5 Old 05-13-2014, 07:30 PM Thread Starter
becraftj2286
1983 CJ8
I know it has a 4 inch Pro Comp Suspension lift and it looks to me like maybe a 1-2 inch body lift at the most. I went back and looked at my notes on the jeep and it also looks like the previous owner purchased a reverse Shackle system. Would that have caused this issue?
post #4 of 5 Old 05-13-2014, 09:09 PM
222Doc
222Doc's Avatar
Intermediate steering shaft= is the one that goes from the steering box to the steering wheel/ column
Flaming river makes custom ones. If you can not fab it.
Or are we talking about the Drag Link.=that goes from the pitman arm on the steering box to the wheel knuckle. Or if a Y set up to a point on the tie rod.
222Doc is offline
post #5 of 5 Old 05-13-2014, 09:49 PM
babytank31
1978 CJ5
I have a 4 inch lift on a 78 cj5 and switched from manual to power steering and purchased a new shaft with a u-joint on both ends. When I installed the new shaft it only had about 1/2 to 3/4 of an inch of slip left before the two halves separated. I assumed that it was in some way due to having a glass body because there is no body lift on the jeep. There was no way in hell I was going to take off down the road with it like that so I cut and lengthened it. Still stumped over it.
babytank31 is offline
