Starts then dies in gear - JeepForum.com
post #1 of 17 Old 09-02-2012, 08:11 PM Thread Starter
miesner
91 Cherokee starts and idles fine then when u go to pull it in gear(auto trans) it shuts right off
miesner is offline
post #2 of 17 Old 09-03-2012, 07:57 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Not common, but loose bolts holding the engine and trans together can cause this.
cruiser54 is offline
post #3 of 17 Old 09-03-2012, 08:22 PM Thread Starter
miesner
It will run for 10-15 mins idling but the second I try n pull it out of park it just shuts off like I turned the key off. I'm getting fuel. I changed the m.a.p. sensor the crank shaft position sensor can't be it cause it wouldn't start. Its stumping me. Wires are good battery is good. Cap rotor plugs coil all good I just don't know.?!?!?!?!?
miesner is offline
post #4 of 17 Old 09-03-2012, 09:42 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Did you even check/inspect the engine to trans bolts?
post #5 of 17 Old 09-03-2012, 09:52 PM Thread Starter
miesner
No I have not.
miesner is offline
post #6 of 17 Old 09-03-2012, 09:54 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Okay. Just asking. Maybe some other guesses will serve you better.
post #7 of 17 Old 09-03-2012, 10:03 PM Thread Starter
miesner
I will check those tomorrow. I'm thinking it could possibly be the torque converter.
miesner is offline
post #8 of 17 Old 09-04-2012, 01:29 AM
Wrenchtwister13
Have you checked the iac motor
Wrenchtwister13 is offline
post #9 of 17 Old 09-04-2012, 07:26 AM Thread Starter
miesner
I don't think its that. That's just my opinion n observation to how it's acting
miesner is offline
post #10 of 17 Old 09-04-2012, 08:33 PM
jsadler
1994 ZJ
I just bought a 94 zj for $500 because it has these same symptoms. The previous owner said it would drive, so long as you got on it to get moving as soon as you put it in gear, but when you slowed down, you had to put it in nuetral or it would stall. He parked it for about 2 years before I found it. He thought it had a bad torque converter. I was leaning more towards a map sensor or iac or something to that effect. I haven't checked anything on it yet. Haven't even picked it up. needs a battery and has 2 flat tires. It's got the 4.0 i6 and auto trans. I'm curious to see what happened to yours, and will let you know what I find on mine.
Will yours run in nuetral? IE: die when you put in gear, or die when you take out of park?
jsadler is offline
post #11 of 17 Old 09-04-2012, 08:50 PM Thread Starter
miesner
I haven't pin pointed the grimlin yet but I'm leaning towards a ecu junk yard parts. Yours sound more like tps or the map sensor
miesner is offline
post #12 of 17 Old 09-05-2012, 06:28 PM Thread Starter
miesner
It was the I.A.C.
miesner is offline
post #13 of 17 Old 09-05-2012, 06:29 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Just dirty or faulty?
post #14 of 17 Old 09-05-2012, 06:40 PM Thread Starter
miesner
Faulty
miesner is offline
post #15 of 17 Old 09-05-2012, 09:26 PM
jsadler
1994 ZJ
Still don't know on mine. The current owner has not delivered the title, so untill he does, the jeep sits in his back yard, and my cash sits in my wallet. Sure hope mines a simple fix like that.
jsadler is offline
