Starting Trouble 1992 XJ Cherokee - JeepForum.com
post #1 of 15 Old 12-04-2013, 12:21 PM Thread Starter
Nick_92Cherokee
1992 XJ Cherokee
Just bought a 1992 Cherokee 4.0L. It has a rough time starting when it cold. Some time it cranks and cranks and will not start but other time the engine will turn over first crank. I replace the spark plugs and wires one by one to make sure that I did not mess up the firing order. I already pulled all of the new plug again to check and make sure they were alright. Plug them all back in. Jeep still runs rough and starting problem still occurs. I know its not the starter. I was thinking of replacing the whole distributor but asking for advice before buying more parts. Also after the jeep shuts of now there is a ticking sound that seems to be coming from the spark plug area. Sound lasts for a few minutes then stop. Help please!!
Nick_92Cherokee is offline
post #2 of 15 Old 12-04-2013, 12:52 PM
uberxj92
1992 XJ Cherokee
Hi and welcome.
When you did the plugs and wires did you change the cap and rotor?
On your 92 turn the key to run not crank and back off 3 times. Leave it "on" on the third time. Have a pen and paper, the check engine light will flash. Write down how many flashes.
All codes are 2 digits so 12 will be flash pause flash flash. 55 is end of codes.
This will help see what'd going on. Get a Haines manual it has the codes in it and is very helpful on mist repairs.
Do this and get back on here tell us the codes its probably not the distributor.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
post #3 of 15 Old 12-04-2013, 05:51 PM Thread Starter
Nick_92Cherokee
1992 XJ Cherokee
Replacing the cap and roter tonight didn't have time to did it the other day. Thanks I'll post what I find
post #4 of 15 Old 12-05-2013, 12:31 PM
uberxj92
1992 XJ Cherokee
Cool keep us up
uberxj92 is offline
post #5 of 15 Old 12-05-2013, 03:36 PM Thread Starter
Nick_92Cherokee
1992 XJ Cherokee
I'm pretty sure I got codes 11 and 12. 11 is no crank signal to computer and 12 battery disconnected. but to me these codes don't make sense. I have not had the battery disconnected and if there wasn't a crank signal to the computer then wouldn't the Jeep just not start at all. It still sometimes starts and doesn't and now stalls out at idle some time. I'm going to double check and make sure i got the right codes.
post #6 of 15 Old 12-05-2013, 04:35 PM Thread Starter
Nick_92Cherokee
1992 XJ Cherokee
Just double checked the codes. It is reading 11 and 12
post #7 of 15 Old 12-05-2013, 04:42 PM Thread Starter
Nick_92Cherokee
1992 XJ Cherokee
Never mind did my research to understand code 11 and it make sense now
post #8 of 15 Old 12-05-2013, 04:58 PM
uberxj92
1992 XJ Cherokee
11 makes sense for the symptoms you have. Cps if you replace it get the OEM one.
12 ... the pcm will sometimes believe the battery has been disconnected if the voltage drops below 10 for 20 seconds. No biggy.
uberxj92 is offline
post #9 of 15 Old 12-06-2013, 09:58 AM Thread Starter
Nick_92Cherokee
1992 XJ Cherokee
Just ordered the sensor. Thanks for the help
post #10 of 15 Old 12-06-2013, 11:10 PM
uberxj92
1992 XJ Cherokee
Np. Keep jeepin
uberxj92 is offline
post #11 of 15 Old 12-07-2013, 07:43 PM Thread Starter
Nick_92Cherokee
1992 XJ Cherokee
So put the censor in and jeep doesn't stall but still runs rough. Computer still shows the same codes. No clue as to why the jeep is running rough.
post #12 of 15 Old 12-07-2013, 09:49 PM
uberxj92
1992 XJ Cherokee
Try disconnecting the battery both wires. After 10 minutes touch the wires together then reconnect. Start it and drive it a while. It'll run Like hell for a bit.
This'll reset the ecm. After a couple of hours of running and driving it should be better. If nit then check the codes again.
Where did you get the sensor?
uberxj92 is offline
post #13 of 15 Old 12-07-2013, 09:52 PM
JbmLaredo
X2^^ if sensor is from auto zone throw it in the garbage
JbmLaredo is offline
post #14 of 15 Old 12-07-2013, 09:54 PM
JbmLaredo
Also a good ground refreshing wouldn't hurt anything
post #15 of 15 Old 12-07-2013, 09:55 PM
uberxj92
1992 XJ Cherokee
We should've mentioned sensors from Napa and pep boys are your best bet.
uberxj92 is offline
