starting trouble - JeepForum.com
post #1 of 5 Old 11-21-2010, 10:36 AM Thread Starter
JRink
1990 XJ Cherokee
starting trouble
I have a 1990 Jeep Cherokee and have been haveing trouble with it not wanting to start. Ive replaced the Coil and Ignition Control Modual and seem to have plenty of fuel preasure. it just doesnt seem to have any Spark can someone out there help me? (As an aditional note it has plenty of cranking power as it also has a new battery)
JRink is offline
post #2 of 5 Old 11-21-2010, 05:28 PM
Ryman12
Maybe time for a new battery? You might also have corroded terminals. Try replacing the terminals first and the battery next (if its old).
Ryman12 is offline
post #3 of 5 Old 11-22-2010, 12:05 AM Thread Starter
JRink
1990 XJ Cherokee
thanks but the battery is new
JRink is offline
post #4 of 5 Old 11-22-2010, 05:00 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Search CPS testing. I would be suspicious of that part failing. For giggles, try unplugging it, spraying out the connector with contact cleaner, and plugging it back in. You might be surprised.
cruiser54 is offline
post #5 of 5 Old 02-09-2011, 09:48 PM Thread Starter
JRink
1990 XJ Cherokee
I want to thank those that Have replied to my problem, I have found and fixed the issue.
It turns out that my problem was caused from The sensor that is inside the Distributor replaced the whole distributor because it was showing signs of corossion due to the fact I live on the oregon coast and the salt air was getting to it. So once again ty for the advice, and may others be able to use this thread as help in the future.
JRink is offline
RB3 trouble. jeep2008 Audio, CB & Ham Radios, GPS, & Electrical 2 08-30-2010 04:13 AM
YJ missing and trouble starting tater_kamik Engines & Drivetrain 0 04-29-2010 05:16 PM
oil pressure and starting trouble on 4.0 24Fan Engines & Drivetrain 1 06-29-2009 09:20 PM
help, having trouble w/ my 8.8 jipjip Engines & Drivetrain 8 02-21-2007 09:55 AM
2nd amp trouble mud4blud Audio, CB & Ham Radios, GPS, & Electrical 3 02-29-2004 09:14 AM
