Starter won't engage, how can I check the wires before replacing the starter - JeepForum.com
post #1 of 3 Old 01-27-2002, 05:44 PM Thread Starter
Brendan
I had trouble with my starter a month or so ago, but it went away. I hit a dead spot in my starter twice, but after I got the engine started, I would turn the key to start and the starter would pop out (not turn) and my engine would rotate it away from the dead spot. I took out my ac today, but I think thats a coincidence. After I tried to start up my jeep all the electric stuff worked, but the starter wouldn't even pop out, much less rotate. I pop started my jeep, and drove it around, but I couldn't get the starter to pop out so I could rotate it. I want to know how I can check the wiring to the starter before I buy a new one. And what I can do to fix these problems if it is indeed wiring. Thanks so much for helping me. Since my jeep in my only car I really need to get it working again. Thanks for any help you can give me.
Duvie
95 YJ 2.5L 5 Speed
Fightin a war against Florida Rust!
Brendan is offline
post #2 of 3 Old 01-27-2002, 06:23 PM
rivertrout10
rivertrout10's Avatar
Removing the starter is easy - take it to Autozone or some place like that and they will test the starter for you. That wont neccesarily test your wiring but will at least eliminate any question in regard to the starter itself.
Good luck,
Derek
Jeep - its a job - not an adventure
rivertrout10 is offline
post #3 of 3 Old 01-27-2002, 10:35 PM
Hal
Hal's Avatar
Did you try a test light?
...good luck
'02 TJ Sport
Hal is offline
Remote starter help please! mahoot207 Audio, CB & Ham Radios, GPS, & Electrical 17 11-18-2009 10:10 AM
HELP!! How do I wire A Chevy starter using the stock jeep wires??? mandng0 Audio, CB & Ham Radios, GPS, & Electrical 4 09-19-2008 11:26 AM
Starter Troubles Maine-yj Engines & Drivetrain 3 12-16-2003 02:43 PM
Best starter Brock Engines & Drivetrain 2 01-15-2003 09:59 AM
Starter tested fine, Wiring is faulty. What/how can I check? HELP?!? Brendan Engines & Drivetrain 4 02-02-2002 11:26 AM
