Starter Motor.. symptoms of a bad one? - JeepForum.com
post #1 of 5 Old 10-16-2008, 04:57 PM Thread Starter
Yardman Harry
O
Yardman Harry's Avatar
Mmmkay guys.. what are the general symptoms of a starter motor that is going bad?
My jeep starts like the battery is drained... So I brought it to get checked, they did a load test and the batt checked out a ok. It also seems that when i drive for a while then turn off and start up again, its even harder to start.
Thanks!
Harry
1996 Jeep Grand Cherokee. V8 - 5.2 litre 242 SelecTrac. SURCO Safari Roof Rack
Hunter Green
1997 Jeep Wrangler Sahara Ed. I6 - 4.0 litre, 4" SL, D44 rear, 4:56 Gears, AA SYE with double cardon custom rear Drive Shaft, IRO Adj CAs, Kevins Rear Adj TB with JOHNNY JOINT end
1999 Mazda Miata MX5 - Jet Black
1990 Jeep Cherokee Sport I6 - 4.0 litre
White
~Junked~
Yardman Harry is offline
post #2 of 5 Old 10-16-2008, 06:58 PM
SniperYJ
Mine was doing the same thing about 3 days ago - it would start fine sometimes, but most of the time I would get nothing at all. The guage was showing normal voltage and I did some playing around with the Jeep and finally ended up taking it to Autozone where they did a test on the starter and everything came back fine. Just for S***s and giggles, I got another one and put it on in the parking lot and Voila! - fixed. I talked to the guy at Autozone and he said that maybe something in the starter was grounding itself out, but I am not sure he knew what he was talking about. Oh well, it works now - that's what matters I guess lol.
SniperYJ is offline
post #3 of 5 Old 10-16-2008, 08:19 PM Thread Starter
Yardman Harry
O
Hmmm.. ok makes me feel a little better... i just dont want to go out and get another starter for the heck of it, only to find out its something else
Thanks!
harry
Hunter Green
White
~Junked~
post #4 of 5 Old 10-18-2008, 12:18 PM
GlennG
Thanks!
Harry
I just had to replace the starter in my CJ5.
I was driving around, stopped and turned off the engine. Went to start it up, and it sounded like the battery had died, you know, made that chunking sound, and the engine kind of turned over?
Well, even with a jump, it made the same sound. Got a push, and popped it, and it started.
I replaced the starter solenoid first, same problem. Replaced the starter, and everything started fine.
GlennG is offline
post #5 of 5 Old 10-20-2008, 02:47 PM Thread Starter
Yardman Harry
O
Cool Man, thanks! Off to buy a starter
Harry
Hunter Green
White
~Junked~
Motor Swap or OEM Motor Mods??? inkpen00 Engines & Drivetrain 7 02-17-2010 07:15 AM
Symptoms of bad pinion angle? webqaz Engines & Drivetrain 8 11-21-2007 10:59 PM
diesel cherokee starter motor blueboy Engines & Drivetrain 0 01-14-2007 08:47 AM
CB: Symptoms of burnt transmiter. RussoGuitar Audio, CB & Ham Radios, GPS, & Electrical 2 12-18-2006 09:33 PM
Starter won't engage, how can I check the wires before replacing the starter Brendan Engines & Drivetrain 2 01-27-2002 10:35 PM
