Stalling issue with my 97 XJ - Page 2 - JeepForum.com
post #16 of 18 Old 09-03-2013, 05:36 AM
XJ-Buzz
1997 XJ Cherokee
Yes. I will,
XJ-Buzz is offline
post #17 of 18 Old 09-09-2013, 10:03 AM Thread Starter
commander0374
1997 XJ Cherokee
Update on the stalling issue.
1 replaced Crankshaft Position Sensor
2 replaced Battery Temperature Sensor
3 replaced O2 sensor in rear of Catalytic converter.
End result: finally after 9 months of XJ ownership my check engine light is out. No more stalling. No more hard starts. No more rough idle.
commander0374 is offline
post #18 of 18 Old 09-09-2013, 10:05 AM Thread Starter
commander0374
1997 XJ Cherokee
Also just a helpful hint:
I was changing my CPS and as I was working the top bolt out it fell into the hole for the CPS and took me about an hour to fish it out if the transmission with a magnet.
So here was my solution to make putting the CPS back in, and avoiding this same problem in the future.
I found 2 super tiny O-rings and placed them around the bolt after I inserted them through the holes in the CPS. This serves 2 functions.
1: it kept the bolts in position making it much easier to get them started and ratcheted in.
2: in the future if I have to remove the CPS then I will not have to worry about them falling into the flywheel housing.
