Stalled while driving - Page 2 - JeepForum.com
post #16 of 19 Old 09-28-2012, 07:26 PM Thread Starter
Jimh64
Originally Posted by pshivers View Post
Check for fuel in the cylinder. If you don't have fuel, it's probably the cps or the ASD relay. If you have fuel, it might be the ignition coil. Ohming out the cps would be the next thing I would do though. The connector is easy to get to, but getting to the sensor and changing it is the hard part.
Dumb question, but how can I check for fuel in the cylinder?
Jimh64 is offline
post #17 of 19 Old 09-28-2012, 08:37 PM
pshivers
2008 KK Liberty
With the spark plug out and the engine cranking over, you should be able to smell gas with the air exiting the hole where the spark plug came out of.
pshivers is offline
post #18 of 19 Old 10-05-2012, 03:48 PM Thread Starter
Jimh64
ok, so I checked for spark, and no spark. I checked for fuel by pushing in the needle on the pressure relief valve on the fuel rail and I have no fuel at all coming out.
Given those checks and the comments here, I assume it is my CPS. I looked underneath and I did see it way up there. Please tell me there is only one bolt holding it on. I think i can get to the bottom bolt from underneath. I can just barel get my arm up there.
If anyone has any suggestions on getting it out, I would appreciate it!
Thanks!
Jimh64 is offline
post #19 of 19 Old 10-06-2012, 04:49 PM Thread Starter
Jimh64
I have a tester, but I am not sure how to "ohm" out the cps. I know you use the 1st and 3rd pin holes, but what do I set my tester at and what shoud the reading be if it is dead?
Jimh64 is offline
