Stalled while driving - JeepForum.com
post #1 of 19 Old 09-21-2012, 10:13 PM Thread Starter
Jimh64
Ugh! Today I was driving just fine. I was going on the on ramp to the highway and my jeep just died. It will crank, but won't even try to start.
Gas is good. I just did a tune up so I know plugs, wires, cap and rotor are good.
I am not sure how to check for spark and someone said it could be the fuel pump. I tried to use the key method for codes, but the engine light never flashed, it just stayed on.
Can someone please help me out?
Jimh64 is offline
post #2 of 19 Old 09-22-2012, 10:46 AM
pshivers
2008 KK Liberty
Same thing just happened to my dad's 94 zj. When you turn the key, see if you can hear the fuel pump prime for 2 seconds. If you do, fuel pump is probably good. Pull a spark plug off, touch the threads to a known good ground, have someone turn the car over. If you don't have spark, smell the open cylinder for gas while cranking. If you don't have spark or fuel, it's probably the crank sensor. They are a known issue. If the computer doesn't see the engine turning, like in a crash or something, for safety it shuts off spark and fuel. You can test the crank sensor with an Ohm Meter. With the key OFF, unplug the crank sensor. With the locking tab on top, you should have 3-4k ohms of resistance. All other combinations of the three pins should have high resistance, 6Meg or higher. If any are low replace the crank sensor.
pshivers is offline
post #3 of 19 Old 09-22-2012, 10:47 AM
pshivers
2008 KK Liberty
3-4k ohms resistance between the first and middle pin. Sorry.
pshivers is offline
post #4 of 19 Old 09-22-2012, 11:11 AM
bmftom83
Had the same thing happen to me last week. Turned out to be the cat converter stopped up.
bmftom83 is offline
post #5 of 19 Old 09-22-2012, 01:40 PM Thread Starter
Jimh64
I just put a new cat on, so I know its not that at least,, thanks!
Jimh64 is offline
post #6 of 19 Old 09-22-2012, 01:42 PM Thread Starter
Jimh64
I don't think I hear the pump running, but Im not sure. If I pull a plug and have spark, does that mean the crank sensor is ok? That would help me eliminate the fuel pump.
Thanks!
Jimh64 is offline
post #7 of 19 Old 09-22-2012, 01:50 PM
pshivers
2008 KK Liberty
Pull the plug, if you have spark and no fuel, you'll have to go down the path of the fuel pump and your crank sensor would be good. Check fuses under the hood. You should at least get a 2 second prime when the key is switched from off to on without trying to start it.
pshivers is offline
post #8 of 19 Old 09-22-2012, 01:56 PM
pshivers
2008 KK Liberty
BTW, don't have a hold of the plug wires while cranking and testing for spark. 20,000 volts don't feel too good. Just thought I'd mention it if you didn't know.
pshivers is offline
post #9 of 19 Old 09-22-2012, 01:56 PM
Pmholli93
Turn the key to the on position, pop the hood. Look along you're fuel line for what looks like a valve stem for like you tire and press it. Be careful. If your fuel pump is working fuel will shoot out.
Pmholli93 is offline
post #10 of 19 Old 09-22-2012, 02:11 PM
pshivers
2008 KK Liberty
A word of caution when pushing the valve on the fuel rail, test for spark first, then test for fuel. You wouldn't want to ignite the fuel you just sprayed under the hood. Use a rag wrapped around a screw driver or something. But you should be able to hear the fuel pump underneath the back seat in the gas tank.
pshivers is offline
post #11 of 19 Old 09-22-2012, 02:57 PM
Pmholli93
Well of course do the spark first. Now if you get spark and no fuel don't assume the pump first. Check the fuel pump relay. You can either buy a new relay and see or you can swap relays somewhere and then see if that circuit works with the relay in it. If it don't then it's the relay. If it does then it's your pump or a stopped up fuel filter
post #12 of 19 Old 09-22-2012, 03:51 PM Thread Starter
Jimh64
How do I hold the plug if I can't hold the wire?
Jimh64 is offline
post #13 of 19 Old 09-22-2012, 05:09 PM
Pmholli93
You can hold it just hold it by a rubber part that has to exposed wire or anything. I do it all the time and have never been shocked. Only way you would get shocked is from holes in the insolation
post #14 of 19 Old 09-28-2012, 05:25 PM Thread Starter
Jimh64
No Spark
Ok, I pulled a spark plug and held it to a ground on the frame and cranked the engine...No Spark...
Does this mean it is probably the cps sensor? I checked the connection and it seemed ok. I didn't even bother checking the fuel pump since I had no spark anyway.
Just a refresher,,, It stalled while I was getting on an on ramp to the highway.
Anything else I can eliminate before trying to tackle that crazy sensor?
Jimh64 is offline
post #15 of 19 Old 09-28-2012, 07:17 PM
pshivers
2008 KK Liberty
Check for fuel in the cylinder. If you don't have fuel, it's probably the cps or the ASD relay. If you have fuel, it might be the ignition coil. Ohming out the cps would be the next thing I would do though. The connector is easy to get to, but getting to the sensor and changing it is the hard part.
pshivers is offline
