spun bearing - JeepForum.com
post #1 of 5 Old 02-20-2007, 01:21 PM Thread Starter
dizz
spun bearing
well im not the best mec around just rebuilt a 304 ran it for about 50 miles and now when i parked it i noticed a ticking sound coming from #1 cylinder drained oil yes there was metal in the oil so i pretty sure i spun a bearing anyway was wondering if i pull the motor can i just flip motor over and replace crank and bearings without removing heads piston and everthing else?
dizz is offline
post #2 of 5 Old 02-20-2007, 03:38 PM
tscuda
50 miles on a fresh engine yes you'll have metal in it. Before you go thru all that work pulling the engine. Drop the pan and just the 1 main cap and check. But you said a ticking noise. lifter/cam?? You might have rounded your cam. How did you break the engine in?
tscuda is offline
post #3 of 5 Old 02-20-2007, 11:40 PM
TXjeepTJ
TXjeepTJ's Avatar
ya like tscuda said metal will be in the fresh engine, everything in the engine needs to get use to each other
did you measure your bearing/crank clearance when rebuilding?
sounds like a lifter sticking, add some lucas oil additive
LS1 powered TJ
C6 Z06 Corvette
TXjeepTJ is offline
post #4 of 5 Old 02-21-2007, 05:18 AM
cjjeeper258
X2 on the stuck lifter. I am guessing that they are hydraulic and you either have a bad one or may not have pumped them up before installation.
To answer your other question on what can be done when pulling the motor:
You can pull the engine, drain it well, flip it and pull the pan. You most likely will not be able to pull the crank with the pistons still in the engine as the rods will fight you.
I, however, have seen people loosen everything up on the bottom end and were able to slide new bearings in and remove the old ones.
To locate the source of your tick, you should take a long screwdriver and touch it in different areas on the motor while it is running and press the handle up to your ear.
You'll find the noise quickly.
cjjeeper258 is offline
post #5 of 5 Old 02-21-2007, 11:29 AM Thread Starter
dizz
thanks for the help pulled motor last night.today toook oil pan and took off #1 piston pulled bearing and it was copper with a few groves in it.so i think that was the prob.yes after looking it might be alot easier to just pull the heads off.man i hate doing stuff twice.
dizz is offline
Rod bearing help... Kharismattack Engines & Drivetrain 14 02-18-2010 10:02 AM
9 inch. Big Bearing or Small Bearing?? (Pics) poloboy406 Engines & Drivetrain 0 01-02-2010 12:52 AM
NV3550 clutch release bearing (throw out bearing) raZe Engines & Drivetrain 4 09-03-2009 01:45 PM
Bearing seat.... STUFF Engines & Drivetrain 2 03-05-2008 08:52 PM
inner bearings got spun? DLoweinc General Jeep & Off-Road Equipment 2 02-09-2005 05:09 PM
