sparkplug guards - JeepForum.com
post #1 of 2 Old 02-02-2006, 09:55 PM Thread Starter
SilverTSi
sparkplug guards
I'm doing my long block swap on my JGC. I have a 318. I was wondering how you can remove those sparkplug guards on the heads? I don't know the correct name for them or I'd do a search. I can think of an easy way to remove them but I don't want to ruin them. So what's the correct way? Thanks!
'97 5.2L Silver TSi 4x4
SilverTSi is offline
post #2 of 2 Old 02-11-2006, 07:26 PM
Traveller
If you are talking about the sheet metal heat guards, I wouldn't worry. With a decent set of wires you don't need them. If you still want to use them, get a can of PB Blaster penetrating oil and soak them down the exhaust manifold bolts real good. Let them sit over night before you start working on them.
You'll need a thin wrench to hold onto the bolts, and a good six point socket to remove the nuts. The PB Blaster oil is a miracle on exhaust hardware. I have yet to break or strip anything after using it.
Traveller is offline
TJ rocker guards..$90 bryans98tj Fabrication Shop 19 12-21-2009 05:12 PM
Diff guards: how necessary? jonalexdeval General Jeep & Off-Road Equipment 17 08-07-2009 09:00 AM
Re-painting Rocker Guards/Corner Guards snowcrash General Jeep & Off-Road Equipment 3 03-01-2008 10:58 PM
Rocker guards Wrangler11 General Jeep & Off-Road Equipment 19 03-31-2007 09:32 AM
