Spark plug Change then missfire starts...HELP! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > Spark plug Change then missfire starts...HELP!
HID's from RuffStuff!Ruffstuff Axle Simple Swap Kit!The Original 3/8" Ruffstuff Diff Cover!
Unread 09-13-2008, 07:04 PM   #1
unlimited4x4
I just swapped plugs and now it is missfiring and a water mist is coming out of the exhaust. I am sure its the rail that sits on tip of the plugs. I took it off, checked everything, and reinstalled....same problem. Any one have a similar experience?
I am embarrassed , this is a easy thing to do. Any help is appreciated.
Thanks
05 Unlimited 4x4
I don't want to take Mommy's car. It doesn't have sky in it like Daddy's. - CJsPerson
unlimited4x4 is offline   Reply With Quote
Unread 09-13-2008, 07:07 PM   #2
lurkeryj
1997 XJ Cherokee
did you over tighten a plug and crack the porcelin?
lurkeryj is offline   Reply With Quote
Unread 09-13-2008, 07:10 PM   #3
unlimited4x4
We'll find out tommorrow....I am going to tear it all down and start over in the morning. I'm frustrated......
What you suggest is a possibility...
05 Unlimited 4x4
Unread 09-13-2008, 08:48 PM   #4
unlimited4x4
So this is strange, the gap on the new plugs (champions) looks smaller than the NGK. BUt the online NGK parts list say the ZFR5n has a gap of 0.028", but the jeep needs .035". I think the plugs are wrong, the new ones are supposed to be pregapped and 0.035".
05 Unlimited 4x4
Unread 09-14-2008, 09:08 AM   #5
Pillswoj
Which champion plugs did you buy? If you bought Platinum plugs you need to make sure they are "double platinum" as the ignition in 2000 + TJ's require that both sides of the electrode be of the same material.
Friends don't let Friends run Bosch
Pillswoj is offline   Reply With Quote
Unread 09-14-2008, 09:29 AM   #6
GPV
Always check the gap before you install. Water mist out of the exhaust concerns me...............................
Sean
2008 Jeep JK Rubicon Unlimited (Bought for Wife)
2007 GMC 2500HD Duramax (Work Horse)
1982 Honda CB 900F Supersport
2001 Honda RC51
GPV is offline   Reply With Quote
Unread 09-14-2008, 09:36 PM   #7
unlimited4x4
Update
Took the plugs back....I have a bad plug in the bunch. They refuse to take them back. I put the old plugs in and it runs fine. I am not sure how to figure out which is bad. But the one thing I noticed, after putting the NGK back in, the ignition rail fit more snug than with the champions. The fit felt sloppy with the champions.
I learned the gap difference between the old and new is that overtime the gap will increase. My new plugs were gapped at 0.035". The old are at 0.055.I may try the truck plugs, but I am thinking on just getting another set of NGK ZFR5N's.
05 Unlimited 4x4
