spark plug cam - JeepForum.com
post #1 of 6 Old 02-14-2012, 05:57 PM Thread Starter
98jpwrnglr
spark plug cam
i just replaced my spark plugs and now my jeep sounds cammed..
could this be a gap issue or something else?
also my fan is really loose, any ideas how to tighten without taking off the front end?
any feedback appreciated!!
thanks guys!
98jpwrnglr is offline
post #2 of 6 Old 02-14-2012, 08:32 PM
swille
When you say cammed is it missing / ruff idle?
I assume this is the radiator water pump fan if so there are 4 bolts facing the water pump and 4 facing the fan clutch if these are tight then the inner bearing is going out on the fan clutch.
swille is offline
post #3 of 6 Old 02-14-2012, 08:40 PM
Idwheelthat
thanks guys!
What did you gap the plugs to?
Idwheelthat is offline
post #4 of 6 Old 02-15-2012, 07:37 AM Thread Starter
98jpwrnglr
yeah it's idle is really messy, what is an ideal gap for the plugs?
all the bolts are tight, it's loose on the bearing and the pulley also feels loose, it tightens with the belt but shouldn't be loose
post #5 of 6 Old 02-15-2012, 07:59 AM
ajmorell
ajmorell's Avatar
Factory gap should be listed on the sticker on the fan shroud or radiator support (provided it's still there)
ajmorell is offline
post #6 of 6 Old 02-15-2012, 08:26 AM Thread Starter
98jpwrnglr
okay thanks alot!
no gap on spark plug 4x4Jeep Engines & Drivetrain 17 11-18-2011 05:44 PM
Spark Plug Color D3f4ult Engines & Drivetrain 6 05-10-2011 09:12 AM
Spark Plug Question GADawgFan Engines & Drivetrain 2 06-10-2008 06:28 PM
Spark Plug Boots Jerry All-Bran Engines & Drivetrain 5 04-15-2006 09:38 AM
spark plug gap badams Engines & Drivetrain 5 07-20-2002 07:59 AM
