Spark Plug Boots - JeepForum.com
post #1 of 6 Old 04-13-2006, 02:18 PM Thread Starter
Jerry All-Bran
Jerry All-Bran's Avatar
Spark Plug Boots
Wanted to change the spark plugs, but the boots won't give. Already ripped one, was wondering what kind of tricks you guys know...
Cheers,
Nov
Jerry All-Bran is offline
post #2 of 6 Old 04-13-2006, 02:29 PM
Matt Gertsch
www.lp.org
Matt Gertsch's Avatar
Put a thin coat of good dielectric grease on the inside of them every time you change plugs.
Derpy Hooves for President in 2012
Matt Gertsch is offline
post #3 of 6 Old 04-13-2006, 08:21 PM Thread Starter
Jerry All-Bran
You see, i kinda want to take them off...and i haven't changed nor touched the boots ever since i got the jeep (2yrs..i know...) and they just won't budge...
post #4 of 6 Old 04-13-2006, 08:25 PM
Test
2007 WK
Use a spark plug wire puller if you aren't already and just try to get a good grip on it. Had the same problem with mine.
Test is offline
post #5 of 6 Old 04-13-2006, 08:35 PM
Dudewayne
Get a a pair of pliars and at the base of the boot, grab it with the pliars while holding the plug wire in your hand. Pull the wire and the boot with the pliars at the same time. arounf the boot, do not crush the plug with the pliars.
If you are replacing the wires anyway, don't worry about the boot, just pull the wire out of the top of the boot and then once the wire is out of the boot grab the end with pliars and pull.
Remember to do one wire at a time to avoid a wire mix up, and the jeep not running at all or firing wrong.
If your plug wires are stuck on that badly, I would say they have been on way too long and should be replaced anyway.
'97 TJ Sport 5 Speed Soft Top and Half Doors, Sliders
Rubicon Spings and Shocks and 31x10.50's
Dreaded 3.07's GONE !! NEW 3.73's !! Front Dana 30 Rear Dana 35
Red Jeep Club Member #350
"I DON'T SUFFER FROM INSANITY....I ENJOY EVERY MINUTE OF IT !!!
Dudewayne is offline
post #6 of 6 Old 04-15-2006, 10:38 AM Thread Starter
Jerry All-Bran
I got them out...the damn things were on there pretty good. Ended up changing the plug wires. Tried taking them out without damaging them, but that didn't workout all that great. Note to self: change spark plugs more frequently. Thanks dudes
who makes the best spark plug? Brendan Engines & Drivetrain 48 08-20-2013 11:15 AM
4.0L Spark Plug Dilemma gmcd Engines & Drivetrain 7 08-12-2009 09:14 PM
spark plug trouble scotth Engines & Drivetrain 2 04-17-2007 10:08 PM
spark plug change 01jeepgrand Audio, CB & Ham Radios, GPS, & Electrical 3 08-22-2005 07:46 PM
spark plug gap badams Engines & Drivetrain 5 07-20-2002 08:59 AM
