Sound under the hood - JeepForum.com
post #1 of 4 Old 10-17-2013, 08:22 PM Thread Starter
mickmeister
What does this sound like? I have checked my fluids and they are good. The belts are good. This squealing sound only happens when the Jeep is idling. It's a 97 TJ. Thanks
Engine Sound
NRA Life Member
mickmeister is offline
post #2 of 4 Old 10-18-2013, 06:01 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Sounds like valvetrain a bit. Get one of these to isolate the sound.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 4 Old 10-18-2013, 06:08 AM
mike_breaker_5
pulleys?
Ratmonkey donation page. all proceeds will go to his family.
it's not much to look at... but it's mine.
5.2lswap, metalcloaks, bedliner, tucked belly, d60's, soon to be nv4500 and d300.
mike_breaker_5 is offline
post #4 of 4 Old 10-18-2013, 04:10 PM
uberxj92
1992 XJ Cherokee
I don't think its valvetrain.
Sounds like the belt. I just had this same thing last week. Turns out the belt was too tight and the alternator was going out. Water and steering and AC when they start to have bearing issues do that too.
Does it go away after a few minutes? If it does then its more than likely alternator.
If you gave it tested take it out to gave it tested that way you can check the bearing.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
