Some Sort of Violent Vibration - JeepForum.com
post #1 of 3 Old 08-20-2017, 07:59 PM Thread Starter
sgreiner1011
Hi All, I have a 2005 Jeep GC Laredo AWD V6. I'm pulling my hair out trying to figure this out. When travelling above 40mph, I get this vibration that shakes the whole Jeep. I'm pretty sure its coming from the front. It doesn't happen constantly though. Its intermittent. Maybe a minute or two in between vibrations and the actual vibrations last for about 5 to 10 seconds. It only happens when keeping the accelerator in a consistent spot going a constant speed (not accelerating, nor slowing down). If I accelerate, the vibration stops. If I slow down with using the brakes, it stops. Shifting into neutral while driving will make it stop as well.
I have changed the front axle isolator bushings (the top one was gone). I have a rebuilt CV joint in the front driveshaft. I replaced both CV axles. Checked the tie rod ends and ball joints and all are good. The front tires are balanced fine as I took it into a shop to check them. All that and I still get a vibration.
Has anybody had to go through something like this? What could it be?
Please help,
Thanks
sgreiner1011 is offline
post #2 of 3 Old 08-26-2017, 03:03 AM Thread Starter
sgreiner1011
So nobody has any idea????
post #3 of 3 Old 08-29-2017, 10:10 PM
mukluk
Possibly a phasing issue between the front and rear driveshafts. Try loading the rear end down so that the suspension squats a bit, see if the vibration persists.
2000 TJ SE
2005 LJ Rubicon
mukluk is offline
