Should I go full synthetic or part or regular oil with a 4.0L 103k miles? - JeepForum.com
post #1 of 4 Old 12-19-2003, 04:04 PM Thread Starter
TheJeepMan
Like the title says, I just bought an XJ with 103k miles (4.0L 93 Cherokee sport 5spd). I have always used synthetic on my Toyota's and Honda's with high miles, but I'm new to the Jeep's 4.0L engine. Will there be a prob with running Castrol Syntec blend with this many miles on the motor? What are everyones opinion on oil types for this Jeep? My concern is running a cleaner oil (synthetic) which could clean out the oil passages and in result cause the jeep to have some small oil leaks around gaskets and rubber and such. What do you all think?
TheJeepMan is offline
post #2 of 4 Old 12-19-2003, 04:12 PM
BigWaylon
tubework is cool...
BigWaylon's Avatar
personally...I'd go with a good quality "normal" oil, and change it regularly...
you might try a blend if you wish, but unless the first 103K were with synthetics I probably wouldn't switch...for the same reason you mentioned (just worded a little different)...the synthetic won't "cause" any leaks, but it mind "find" some that were already there but clogged up...
I've never been a fan of synthetic motor oils, but I do like synthetic greases and gear lubes...
just my $.02...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
BigWaylon is offline
post #3 of 4 Old 12-19-2003, 04:27 PM
xxxflhrci
xxxflhrci's Avatar
Use whatever was put in it by the previous owner. Whatever it was, it worked for 103k and kept the engine in good shape, right, or you wouldn't have bought it.
xxxflhrci is offline
post #4 of 4 Old 12-20-2003, 03:10 PM
RTStork
RTStork's Avatar
I agree with BigWaylon. The syntheic might dissolve some sludge around the seals and then you could start leaking oil. Now, thats not necessarily a bad thing cause then you would know what seals, etc needs replacing, but its up to you. I use Amsoil synthetic in all my vehicles, but I've had them since they were new.
00 Jeep Wrangler Sport 4.0L - 2" BB, 2"BL, 33's, 4.56 gears, Auburn in rear
Pics of my Jeep http://community.webshots.com/album/76582748MYTDqR
RTStork is offline
Mag 1 Full Synthetic magnusrw Engines & Drivetrain 3 07-12-2013 02:34 PM
4wd part-time and full-time question flyboy14295 Engines & Drivetrain 2 01-29-2009 03:22 AM
Changed to Full Synthetic Oil and have a leak. SpoiledRotten Engines & Drivetrain 7 08-05-2008 09:06 AM
Synthetic Oil VS Regular Oil robthebert Engines & Drivetrain 36 07-16-2007 10:17 PM
Synthetic Oil to Regular Oil Problems! Big92Jeep Engines & Drivetrain 5 12-07-2001 01:05 PM
