Shipped YJ, now drive shafts are spinning with no movement? - JeepForum.com
post #1 of 70 Old 01-09-2014, 08:45 AM Thread Starter
Tokoloshe
Hey all,
I just moved to TN and had my YJ shipped to meet me. When it arrived I drove it off the transport truck as the driver reported having difficulty getting it on and had my buddy drive it onto the transport truck in NC. It seemed like it was having difficult engaging gears and after driving 20 yards would not produce movement fwd or backward in any gear.
I am able to shift into gear, the engine runs fine, both drive shafts turn but there is no vehicular movement forward or backward. Occasionally I can hear some minimal grinding that is very short lived when I shift into different gears.
I am not aware of any specific damage to the vehicle as it was running fine when I left but there were 2 weeks that I did not have eyes on the vehicle...
Engine: 350 Chevy small block, SM420 Transmission. 35" tires. Stock transfer case, axles, diff etc. I am semi-handy and can follow instructions well.
I would really appreciate any help in terms of diagnosis, replacement parts/instructions, cost estimates and will gladly provide any info needed.
Thanks in advance for the help!
T.
Tokoloshe is offline
post #2 of 70 Old 01-09-2014, 09:52 AM
scott5star
scott5star's Avatar
I hope some guys step up on this one, same problem here
Fat isn't a handicap!
scott5star is offline
post #3 of 70 Old 01-09-2014, 11:15 AM
vadslram
Drive shafts turning, wheels not
But you drove it off the transport?
For that to happen either ALL the teeth on both pinions had to get sheared off or the ring gears are missing teeth that by strange coincidence brought to the same position on the front an rear at the same time. And it had to happen at the ~3 mph you drove off the transport.
If I were a betting man I would give even odds of either one of those happened or that someone stole both your diffs in transport....and that's about the same odds of having your kidneys stolen in a hotel bathtub filled with ice.
vadslram is offline
post #4 of 70 Old 01-09-2014, 11:18 AM
biffgnar
biffgnar's Avatar
Or are driveshafts turning when it rolls on the wheels but nothing happening when engine turned on?
biffgnar is online now
post #5 of 70 Old 01-09-2014, 06:07 PM Thread Starter
Tokoloshe
Thanks for the help guys.
Yeah I cannot explain it either and yes it sounds weird to me!
If someone stole my diffs they are idiots as they are stock....
Biffngar I am not quite sure what you are asking, can you please rephrase? Both drive shafts turn when in any gear and the wheels don't turn.
Is there a way to confirm the presence of (damaged) diffs without removing the covers?
Thanks again,
T
post #6 of 70 Old 01-10-2014, 11:34 AM
Evildriver-3
Either your pinion gear in both diffs broke, or the spiders in both diffs broke, or an axle in each. You have to remove the covers and see.
If you do not remove the covers and see you'll never know which or all you need
1995 Jeep gc ltd, 2005 Jeep gc ltd , 71 Dart, 73 RR 440-6pk, 78 Mag GT, 85 Power Ram W-350, 92 Daytona, 99 Dakota, 08 Ram 2500
Less than 8 is like playing with half a deck
]=Supershafts=[
Long Island Motorsports Association
Evildriver-3 is offline
post #7 of 70 Old 01-10-2014, 08:16 PM
laybackman
Bikini Bridge Inspector
laybackman's Avatar
2010 JK Wrangler
Originally Posted by Tokoloshe View Post
Hey all,
T.
I'm thinking that you should check the shift linkage on your transfer case. Make sure the T-case is engaged in some drive mode. Does the d-shafts turn when you are coasting? that could be friction.
The chances of blowing both ring and pinions while loading it up or off loading it from a trailer is about as likely as hitting the lottery...twice.
It drove for you then quit. Did the RPM's go up like you threw it into neutral?
I think it is T-case related somehow.
Do you know what was good about the good old days? I wasn't good, And I wasn't old!
Senators and Congressman should wear uniforms like NASCAR drivers so we could identify their corporate sponsors....
laybackman is online now
post #8 of 70 Old 01-10-2014, 08:22 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
One more question for you.
Are you saying that the drive shafts turn when you increase the RPMS of your running engine? Is it in 4WD? Shift it into 2WD and see if just rear shaft turns.
If this is happening or you can make this happen then you need to pull both front and rear differential covers.....
post #9 of 70 Old 01-14-2014, 07:52 PM Thread Starter
Tokoloshe
Thanks for the help thus far yes. Been crazy busy at work and home. I checked the diff covers and neither looked like they have been tampered with.
I will see if I can get someone to check the drive shaft in 2wd.
Cheers,
T
post #10 of 70 Old 01-19-2014, 05:14 PM Thread Starter
Tokoloshe
Ok so I checked the drive shafts today, they both rotated regardless of gear.
I tried to shift into 2WD but am unsure if I was able to as I ditched the vacuum operated 4WD for a cable operated system...
Does anybody have any other ideas apart from both differentials?
If not, any suggestions for rebuild kits (I have never messed with diffs before but am willing to try).
Thanks in advance for the help.
T
post #11 of 70 Old 01-19-2014, 05:16 PM Thread Starter
Tokoloshe
Laybackman,
I have no idea how it happened....why are you thinking transfer case?
Learning here
T
post #12 of 70 Old 01-19-2014, 05:55 PM
laybackman
laybackman's Avatar
2010 JK Wrangler
Laybackman,
Learning here
T
This Jeep does not drive in gear so driveshaft movement is not happening due to the engine turning.
The rear drive shaft is always hooked up to the pinion gear so friction can make it turn. The front driveshaft would also be turning if the front axle is engaged. Don't assume it is not engaged.
If the T- case is in neutral you go nowhere EVEN if you are in FWD.
I would get this Jeep up on four jack stands or a body lift and see if you can turn the D shafts and makes some wheels turn.
IF the T-case is engaged and the tranny is in gear you should not be able to turn anything by hand. If you can, then the T-case would be the prime suspect.
I still think it is a T-case linkage issue.
post #13 of 70 Old 01-19-2014, 06:06 PM
Evildriver-3
If the shafts are turning AND the vehicle/jeep/car/whatever is not moving, the problem is not at the tcase.
Don't matter if it's in 2x or 4x, if the driveshafts ARE turning and the vehicle in question is not moving, the problem IS at the diffs
]=Supershafts=[
post #14 of 70 Old 01-19-2014, 06:09 PM
Evildriver-3
If the vehicle is on the floor whether the case is in neutral or not, IF you can turn the shafts YOU have problems with your diffs.
How could you turn the shaft if the vehicle is on the floor regardless of the trans or tcase selection, you could take the motor trans and tcase and remove it , you still can not turn a driveshaft with the vehicles tires on the floor
]=Supershafts=[
post #15 of 70 Old 01-20-2014, 01:52 PM
vadslram
Even with open diffs the drive shafts WILL NOT turn without spinning at least one axle.
The pinion gear is hard to the universals(one solid stub shaft) so if the shaft is turning, the pinion is too.the connection between the pinion and the axle carrier is gear teeth.
JUST THINKING, if your front 4wd disco is open AND you either had a PO install towing discos on the rear or one axle broke, you could be spinning the diconnected axle of each end. It's a long shot but at least a possibility.
vadslram is offline
