Shifts fine Driveshaft spins jeep wont move - JeepForum.com
post #1 of 10 Old 06-11-2012, 05:36 PM Thread Starter
john88YJ
Got an 88 4.2, ba10 stock except for 3in body lift, 32x12.5s.
While back was at a stop sign to turn right. took off pretty hard moved like 10ft and heard/felt loud bang. Similar in feel/noise to taking with a bad tranny mount except louder. I get back on the gas and it does it like 2 more times and then everything fine once i got up in speed. 1/4 mile later it does it again while driving staedy at 35mph. just one loud bang, jerk of the jeep, then went along fine. Then everytime i wood stop and get going, it would bang and randomly down the road going straight. then i noitced it would do it on right turns and up my steepish driveway. went up and down driveway a few times to try to pinpoint the noise better... anyway eventually car wouldnt move anymore. shifted fine but as soon as the clutch would grab in any gear and power was applied all id get was banging. It sounded as if it was coming from the transfer case or rear of trans. So i pulled the transmission and TC, rebuilt the tc, new clutch, rear main seal, new crank pilot bearing. even though they all seemed fine. Put all back together.
Anyway, jeep still not moving. what i missed before is that when in gear the driveshaft is spinning. jeep just not moving. banging is mosltly gone now. Basically I can put it in gear, let off the clutch with no gas, jeep doesnt stall, and driveshaft will spin but the jeep just sits there. One thing is that in reverse like 1 try in 20, if work the gas/clutch very slow, something will catch It will bang but reverse will work for little while, though banging most of the time.
im guessing now that the rear is bad in some way??? I have no experience at all with the rear. Havent had a chance to pull the cover yet.
What does it sound like it could be? ThanX
john88YJ is offline
post #2 of 10 Old 06-11-2012, 07:42 PM
Attwanl
Sounds like your rear differential took a dump. Pull the cover and check it out. It happened to me about 3 months ago. I rebuilt it and put a Detroit true trac in.
What happened?
Attwanl is offline
post #3 of 10 Old 06-11-2012, 07:56 PM
Roxy02
Junior Member
Roxy02's Avatar
Put it in 4x4 see if it will move . If it does then yeah it's your rear
Roxy02 is offline
post #4 of 10 Old 06-12-2012, 05:37 PM Thread Starter
john88YJ
Got time took off the cover and pulled out a hand full of teeth!! Looks like the spiders gears went.... does the whole carrier ahve to come out to get the gears out? what all do I need to do and buy to remove and replace them? Just need stock replacements for now... ThanX
john88YJ is offline
post #5 of 10 Old 06-12-2012, 06:20 PM
Attwanl
First find out what axle you have ... AMC 20... Dana etc.... You can order just the spider gears, but it depends on how bad it is on wether on not you need a new carrier. Pretty sure you can change them with the carrier in, easier with it out on a bench,but you will have to at least pull you axles. All the grit from the gears coming apart are swimming around in the carrier and pinion bearings, be sure and flush everything, and check out the bearings. Might want to get a bearing kit. If you don't replace the ring and pinion it is fairly easy. Kinda labor intense but not too bad. I just did mine.
What happened?
Attwanl is offline
post #6 of 10 Old 06-26-2012, 05:26 AM Thread Starter
john88YJ
ok its a dana 35..... long story short, got new spider gears at the store.... didnt fit gave me wrong ones. had to return them. Couldnt find just the gears for mine so I bought a powertrax no slip system. Again cant this thing to fit either. WTF!!!
john88YJ is offline
post #7 of 10 Old 06-28-2012, 06:23 PM
Attwanl
Did you take the carrier out? What exactly isn't fitting?
What happened?
Attwanl is offline
post #8 of 10 Old 06-28-2012, 07:27 PM
90DesertTanYJ
I would either find a new parts place or find out if someone upgraded or changed your Axle.
90DesertTanYJ is offline
post #9 of 10 Old 06-28-2012, 09:42 PM
Attwanl
Can you post some pix
What happened?
Attwanl is offline
post #10 of 10 Old 07-04-2012, 11:20 PM Thread Starter
john88YJ
Ok supposedly Richmond boxed the wrong part. Overnighted the right one and it fit......... drove it for two days AND NOW ITS THE SAME THING ALL OVER AGAIN!!!! SAME NOISE I HAD WITH THE SPIDER GEARS!!!! I was driving it without the trans tunnel cover or shifter boots on and sounds now as if its in the tranny this time. Bangs and is noisey as hell in first. it moves in first but not smoothly or quickly got to shift to second as quick as possible then it runs much more smoothly but not 100%. 2nd-4th gear have a slight bang/tap noise that seems to increase in frequency but not loudness or harshness with rpm. WTF!?!? Does it sound like my tranny is now going? throwout bearing possibly?
And if I push the clutch pedal in it goes away
john88YJ is offline
Driveshaft spins but wheels don't MRANDWGR Engines & Drivetrain 2 10-16-2010 06:36 PM
body mount bolt spins in the captive nut and wont come out chipman General Jeep & Off-Road Equipment 3 04-15-2010 09:56 AM
power seats wont move Pitch Black Audio, CB & Ham Radios, GPS, & Electrical 0 01-18-2010 06:05 PM
NGS 370 Shifts freely between gears w/ no clutch; Jeep no move NavinRJohnson Engines & Drivetrain 0 05-19-2009 02:25 PM
Jeep wont move!?!? Big Blue Jeep Engines & Drivetrain 3 10-14-2007 09:16 PM
