Shifter question - JeepForum.com
post #1 of 1 Old 06-03-2012, 06:23 PM Thread Starter
Mac54
Shifter question
Have a question. Just recently boought a 05 Unlimited with a lift and 33's (first ever Jeep) and finally was able to take it out in the woods- Starting off the day when I tried to shift if to 4 low it was finikie. But it finally took. By the end of the night when I tried putting it back in 4lo It would pop out of gear, grinding, etc when I was trying different ways to get it in. I was trying to pull it in so much it was loving the plastic column surrounding it but it just didnt want to go in. Now the shifter itself squeeks as your going down the road in 2wd. Whats causing this? Is there a cable linkage that isnt tight enough that needs to be tightened?
Mac54 is offline
Shock shifter question C54 Fabrication Shop 4 01-07-2012 07:27 AM
shifter silverhoarse Engines & Drivetrain 0 03-16-2010 11:27 PM
New Shifter Rockiholic Cheap Tricks & Fixes 22 10-02-2008 06:58 PM
Which Shifter? Millinski Engines & Drivetrain 0 04-13-2006 06:59 PM
did you break your shifter knob of your shifter 2cjs Cheap Tricks & Fixes 1 04-25-2005 05:37 PM
