shifter/linkage backwards - Help - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Engines & Drivetrain > shifter/linkage backwards - Help
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRough Country Lift Kits and Parts!FREE, FREE, FREE EVENT!! Save big on Lockers now till Apri
Unread 08-23-2013, 12:12 PM   #1
Zeke_
HELP. Suggestions welcome. I made a dumb-*** mistake, but haven't figured out just what, yet.
Just swapped an AX15 and NP231 into my '87 YJ. (put wider chain/gears and 6 planetary into the np231).
Problem: Instead of 2H, 4H, N, 4L. Now I have (starting from front) N, 4H, 2H.
So everything is backwards and I can't get into 4L at all.
I thought the linkage was on correctly, but perhaps not. Before I rip into this, does anyone have any opinions on what we did wrong? As in, could we have mounted the linkage incorrectly? Or is there any reason to think the vacuum lines may be a culprit?
Figured I'd ask here in case anyone can visualize what I did wrong that would cause this.
Zeke_ is offline   Reply With Quote Quick reply to this message
