shifter knob rotated after lift - JeepForum.com
post #1 of 4 Old 02-05-2013, 06:31 AM Thread Starter
Pathogen1337
04 wrangler 2.4L 1" bl, 2" spacer
After adding the lift I noticed over time that the shifting knob was rotating. I haven't noticed any issue. It seemed to have stopped rotating (clockwise) at about 95 degrees from straight.
Pathogen1337 is offline
post #2 of 4 Old 02-05-2013, 06:47 AM
mdm
Farm Wheeler
Doubt it had anything to do with the lift.
If it bothers you remove plastic cap, tighten nut, reinstall cap with shift pattern positioned properly.
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #3 of 4 Old 02-05-2013, 05:39 PM Thread Starter
Pathogen1337
well I mean the hole shifter rotated I have never removed the knob so I know it didn't rotate around the shifter
post #4 of 4 Old 02-06-2013, 10:42 AM
seattle_yj
I think you mean the stick rotated. Maybe it's not seated correctly. Just pull up the boot and bezel and check. It has nothing to do with lift, just coincidence.
seattle_yj is offline
