Shift clunk in 2H, fine in 4H - JeepForum.com
post #1 of 2 Old 04-03-2012, 07:17 AM Thread Starter
burnoutjeep
My jeep TJ makes a hard "clunk" when I'm shifting gears in 2H. It occurs at about the half way point on the clutch pedal. If I let out the clutch VERY slowly, it engages much smoother. When I put it in 4H, there is no problem. I can shift fast without any clunk. Does anybody know what the cause may be?
I have a 2000 TJ, 4.0 I6, NV3550, NP231J, Skyjacker 4" lift, 1" TC spacer drop, stock rear DS, Dana 44 rear with Detroit locker, Dana 30 front.
Thanks for the help.
burnoutjeep is offline
post #2 of 2 Old 06-01-2012, 06:09 PM
tcole2007
Same issue please help. Ujoints are good. I have a Stock axles with a lunchbox locker in the rear. Possible bad pinion bearing?
tcole2007 is offline
Starts fine!! Then dies? mdc0404 Engines & Drivetrain 4 10-23-2008 05:58 PM
4.0L runs fine, then misses like mad... fordraceboy Engines & Drivetrain 0 09-08-2008 11:17 PM
will 35s fit fine on 08 4dr jk w/2.5" lift gofastviper Tires & Wheels 1 04-05-2008 10:32 AM
transfer case shift lever hard to shift phant0omx Engines & Drivetrain 1 08-18-2006 08:59 PM
OK fine then ... a Dana 44 LOCKED UP General Jeep & Off-Road Equipment 8 06-03-2003 01:31 PM
