Shakes at initial take off in 1st and reverse - Page 2 - JeepForum.com
post #16 of 24 Old 08-06-2012, 05:53 AM
mdm
Farm Wheeler
Originally Posted by Wrenchtwister13 View Post
Did you have the flywheel machined when you changed the clutch
Really?
Keep in mind that free advice can frequently be worth less than you pay for it.
mdm is offline
post #17 of 24 Old 08-10-2012, 10:21 AM
YjStrangler92
[QUOTE="mdm"]
you would b surprised how many corners some people cut. I try to cover everything once myself. Id rather be wheelin then workin on it.lol
YjStrangler92 is offline
post #18 of 24 Old 08-10-2012, 10:53 AM
mdm
Farm Wheeler
I wouldn't be surprised at all. I've seen too much of it over the years.
There are two problems with Wrenchtwister13's post:
The biggest problem is that the FSM specifically says to NOT machine the flywheel. The surface has a domed shape which machining will cut off. There have been several people around here that have machined the flywheel and claim to have no problems. However, there are also several folks that have reported problems with the clutch not engaging smoothly after machining the flywheel. The fact that you don't machine the TJ flywheel had already been mentioned in previous posts.
The most obvious problem with his post is that the OP stated that he had installed a new flywheel. What would be the point of machining a new flywheel?
mdm is offline
post #19 of 24 Old 08-10-2012, 11:24 AM
YjStrangler92
are u not supposed to turn a flywheel on a yj eithier?
post #20 of 24 Old 08-10-2012, 01:26 PM
mdm
Farm Wheeler
Don't know. I haven't worked a YJ clutch. But they seem to use the same flywheel so I'd assume you shouldn't turn the YJ flywheel either.
mdm is offline
post #21 of 24 Old 08-10-2012, 04:25 PM
winterfunguy
As a level 4 Jeep Driveline tech I feel the need to chime in on this one. First off the NTH (noise vibration and harshness) sounds like one of 3 possible issues. First check the trans mount for tears or a soft/squishy feel to the rubber...if the rubber is not "hard" replace the mount. Jack the rear end up on the pumpkin and set a jackstand on each axle tube and support the vehicle on the stands...spin the drive shaft and see if it binds...if it does you need to install a SYE and CV shaft ...if it doesn't bind then your input bearing is bad in trans. Check the driveline for binding and/or severe driveline angles.
winterfunguy is offline
post #22 of 24 Old 08-10-2012, 06:16 PM
Wrenchtwister13
The flywheel should be replaced or machined either way it needs a new surfuce to mate to
Wrenchtwister13 is offline
post #23 of 24 Old 08-10-2012, 11:48 PM
Wrenchtwister13
I did not see that he had replaced the flywheel check the pinion angle on the rear diff do you have adjustable rear control arms
post #24 of 24 Old 11-01-2013, 09:31 PM
msweber97
It shows in first post he replaced flywheel 3 days ago!
msweber97 is offline
