serious engine guys i need help, 350 chevy identification!! - JeepForum.com
post #1 of 6 Old 03-09-2004, 08:00 PM Thread Starter
79cj360
ok i got a motor from a buddy of mine im building into a 383 stroker. the motor blew up. the one cylinder has some water in it when i pulled the heads off and had a destroyed piston, and cracked the piston rod in 2. the heads and the block are fine. the crank is shot from the rod hitting it and the one pistons/ rod combo are shot.
i checked it all out and everything around this is fine, block is perfect still
now heres my question. i looked up the casting number int he heads. #3998993. this id comes up as a "hencho en mexico" goodwrinch crate motor.
heres is the kicker, i cant find jack on these motors. i found out the cc of the heads are 75cc thats it. id like to find out valve sizes, bore of the block without taking it somewhere. if its to much hastle i have a virgin stock block also. these are 4-bolt blocks and i really would like to use em.
does anyone know where i could find out about this hencho en mexico crap. thanx a lot
john
79 cj7
70 amx 360
turbo 350
12 inch lift
39.5's
np 208
re quick disconnects
rancho shocks
cutom driveshafts
snorkel
14 bolt rear
international dana 70 front w/closed knuckles
" damn modification bug bit me hard, so im bittin back!!"
"Go mud or go home"
79cj360 is offline
post #2 of 6 Old 03-10-2004, 03:17 PM
serjustin
I would be all to worried about the head casting numbers. Check teh block casting numbers to see what they come out with.
serjustin is offline
post #3 of 6 Old 03-10-2004, 07:34 PM Thread Starter
79cj360
i talked to a guy that runs a casting number website and tyhis is what he said
"Most were 1.94/1.5 valves and they have 160cc intake ports. they were also used on production motors in the 70's. They are good heavy casting heads.
i gave him the castings and everything. im gonna get the block here this weekend and do that number as well to find bore size.
to get the block prepped and bored and all for the stroker setup is $250+shipping. chevy is so cheap i love it
john
79 cj7
70 amx 360
turbo 350
12 inch lift
39.5's
np 208
rancho shocks
cutom driveshafts
snorkel
14 bolt rear
"Go mud or go home"
79cj360 is offline
post #4 of 6 Old 03-11-2004, 09:15 AM
CJ-5
Builder
I think that you never had the relief work done to the lower block.
You gotta do a little grinding on a 350 block for the 400 crank to work properly.
Regarding the rest, if all you need to know are the valve sizes, bore and stroke measurements etc, Measure it out......
How easy is that ???
I don't wanna come off wrong here, but it sounds to me like you went into a project that is a little too deep for your experience and failed to do all the preliminary "homework"
Machinists get paid not for being able to run a lathe, but cause they can do the required math involved in running that machine.
No offense meant here to anyone.
CJ-5 is offline
post #5 of 6 Old 03-11-2004, 10:07 AM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
I would imagine it has a 4" bore and 1.94/1.5 inch valves. If you're gonna do engine rebuild work you might as well pick up a good micrometer. Then, you can measure everything out. I would definately have the block and heads magnafluxed to check for cracks after catastrophic internal damage. You don't want to start sinking lots of $$$ into an 8 cylinder boat anchor..
BESRK is offline
post #6 of 6 Old 03-14-2004, 04:48 PM Thread Starter
79cj360
oh ive done my homework and this is definately not out of my league at all. this to me is easy. i did a little reading up about compressions and such and i should put out about 400-450hp.
the block will be dipped and fluxed to check for cracks. it will be decked and bored otu .30 over. it should have the stock bore. waiting for someone to get back to me on this.
i would go by a mic but im out of money at this time for about a week and the stores around here suck so i have to order one. by the time i get it ill knwo allready.
dotn worry man no offense taken. i read up about putting the 400 crank in a chevy and the block has to be cut fo rthe stroker setup and im ordering a special crank for the setup.
thanx for the help
john
79 cj7
70 amx 360
turbo 350
12 inch lift
39.5's
np 208
rancho shocks
cutom driveshafts
snorkel
14 bolt rear
"Go mud or go home"
79cj360 is offline
Any carb guys? Rochester Quad on the Chevy 305 in my Jeep learfxr Engines & Drivetrain 5 08-12-2009 06:51 PM
Need help with engine identification Lunchbox2011 General Jeep & Off-Road Equipment 1 12-13-2008 02:10 PM
anyone with a nv3550 from a 4.3l chevy engine schecterguy Engines & Drivetrain 0 02-26-2008 06:22 PM
Radiator with 4.3 chevy engine swap redrock82 Engines & Drivetrain 2 04-27-2007 12:27 AM
Chevy engine question StevieC Engines & Drivetrain 1 09-10-2001 10:28 PM
